Hello,
I use OS 1.10.0 and want to add daylighting sensor using "Add Daylight Sensor at the Center of Space” measure. However, after I add daylighting sensor in os file and check the E+ file, it seems daylighting control is not created in E+ file and I cannot see any effect on lighting energy because of daylighting sensor. Do I miss anything?
Also, is there any place in OS platform where I could check daylighting sensor setup? Thanks.
