I was trying to simulate in Eplus a double skin façade with four vertical thermal zones (subzones) when I got this Warning: "Inside surface heat balance did not converge with Max Temp Difference [C] =2.026E-003 vs Max Allowed Temp Diff [C] =2.000E-003"
What's the correlation with Heat balance algorithm? Can anyone help me?
Thank You
