I try to run View Data mesure, but it makes the simulation to fail. Below I'm pasting a copy of the last mesages in simulation windows. Does anybody know what is hapenning.
Continuing Simulation at 12/24 for RUN PERIOD 1
Updating Shadowing Calculations, Start Date=12/31
Writing tabular output file results using HTML format.
Computing Life Cycle Costs and Reporting
Writing final SQL reports
EnergyPlus Run Time=00hr 01min 9.89sec
Script executing from: C:/Users/Lem/AppData/Local/Temp/OpenStudio.cY3416/resources/run/6-UserScript-0
Found argument 'file_source' with value 'Last OSM'.
Found argument 'reporting_frequency' with value 'Hourly'.
Found argument 'variable1_name' with value 'Surface Outside Face Temperature'.
Found argument 'variable2_name' with value 'Surface Inside Face Temperature'.
Found argument 'variable3_name' with value 'Zone Mean Radiant Temperature'.
Found UserScript 'ViewData'.
