Hi All, I just wanted to ask about using intersecting in sketchup plugin and stand alone measure for surface matching. When I use Sketchup plugin I get problems of generation of small surface and this does not happen while using surface matching stand a lone measure.
I remember @David Goldwasser said in one of my previously asked question that for stand alone measure if I do intend to have interior subsurfaces, OpenStudio won't find surface match unless the subsurface exists in both surfaces. So keeping this in mind e.g. if a room and corridor are two separate zones, then how this comment will fit into this situation? I have to draw door in both zones (corridor and room)?
@David Goldwasee: I would appreciate your help.
Thanks in advance.
Kindest Regards Waseem
