Is it possible to link plc and open studio? what about energy plus?
I'm going to simulate a controllable external shading for a building. Is open studio able to simulate thid dynamic model? What about energyplus? and If it isn't able to simulate I will use PLC for programming the external shading. then I want to know what will be the effect of using this controlled xternal shading on building cooling demand. Is it possible to import the plc program to openstudio or energyplus? Thank you
I'm going to simulate a controllable external shading for a building. Is open studio able to simulate thid dynamic model? What about energyplus? and If it isn't able to simulate I will use PLC for programming the external shading. then I want to know what will be the effect of using this controlled xternal external shading on building cooling demand. Is OpenStudio able to simulate this dynamic model? What about EnergyPlus?
If it isn't able to simulate I will use PLC (programmable logic controller) for programming the external shading. Is it possible to import the plc PLC program to openstudio OpenStudio or energyplus? Thank you EnergyPlus?
Is it possible to simulate controlled external shading? And if not, is it possible to link plc and open studio? what about energy plus?to an external logic controller?
I'm going to simulate a controllable external shading for a building. I want to know what will be the effect of using this controlled external shading on building cooling demand. Is OpenStudio able to simulate this dynamic model? What about EnergyPlus?
If it isn't able to simulate I will use PLC (programmable logic controller) for programming the external shading. Is it possible to import the PLC program to OpenStudio or EnergyPlus?
Is it possible to simulate controlled external shading? And if not, is it possible to link to an external logic controller?plc and open studio? what about energy plus?
If it isn't able to simulate I will use PLC (programmable logic controller) for programming the external shading. Is shading, is it possible to import the PLC program to OpenStudio or EnergyPlus?
If it isn't able to simulate I will use PLC (programmable logic controller) for programming the external shading, is it possible to import the PLC program to OpenStudio or EnergyPlus?
