I have always used EP-launch for running my simulations, no I need to run it from command prompt in windows. So I read the auxiliary programs pdf which says: ".... In the same directory EnergyPlus expects in.idf, the input data file; Energy+.idd, the data dictionary file; in.epw, the weather file (needed only if there is a RunPeriod in the input); and optionally Energy+.ini, the initialization file."
But I have only Energy+.idd file in C:\Energyplus 8-4-0 directory. where should I find in.idf , in.epw and Energy+.ini?
Thanks
