I'm trying to put a pv system to the facade, and get the produced electricity, I wrote the IDF as following, but I can not find the variable outputs in the cvs file. What is the right process for this?
Version, 8.4; !- Version Identifier
Building, Office Example,
!- Name ,
!- North Axis {deg} ,
!- Terrain ,
!- Loads Convergence Tolerance Value
!- Temperature Convergence Tolerance Value {deltaC} ,
!- Solar Distribution ,
!- Maximum Number of Warmup Days ;
!- Minimum Number of Warmup DaysZone, B_2OG_4,
!- Name -0,
!- Direction of Relative North {deg} 14.9999990463257, !- X Origin {m} 4.99999999999999, !- Y Origin {m} 6.8, !- Z Origin {m} ,
!- Type ,
!- Multiplier ,
!- Ceiling Height {m} ,
!- Volume {m3} ,
!- Floor Area {m2} ,
!- Zone Inside Convection Algorithm
!- Zone Outside Convection AlgorithmBuildingSurface:Detailed, Surface 319, !- Name Floor,
!- Surface Type ADJ_CEILING,
!- Construction Name B_2OG_4,
!- Zone Name Adiabatic,
!- Outside Boundary Condition ,
!- Outside Boundary Condition Object
NoSun,
!- Sun Exposure NoWind,
!- Wind Exposure ,
!- View Factor to Ground ,
!- Number of Vertices 0, 0, 0,
!- X,Y,Z Vertex 1 {m} 0, -4.99999999999999, 0, !- X,Y,Z Vertex 2 {m}
-3.74999904632568, -4.99999999999999, 0, !- X,Y,Z Vertex 3 {m}
-3.74999904632568, 0, 0; !- X,Y,Z Vertex 4 {m}BuildingSurface:Detailed, Surface 320, !- Name Wall,
!- Surface Type ADJ_WALL,
NoSun,
!- Wind Exposure ,
!- Number of Vertices 0, -4.99999999999999, 3.4, !- X,Y,Z Vertex 1 {m} 0, -4.99999999999999, 0, !- X,Y,Z Vertex 2 {m} 0, 0, 0,
!- X,Y,Z Vertex 3 {m} 0, 0, 3.4;
!- X,Y,Z Vertex 4 {m}BuildingSurface:Detailed, Surface 321, !- Name Wall,
!- Surface Type EXT_WALL,
!- Zone Name Outdoors,
SunExposed,
!- Sun Exposure WindExposed,
!- Wind Exposure ,
-3.74999904632568, -4.99999999999999, 3.4, !- X,Y,Z Vertex 1 {m} -3.74999904632568, -4.99999999999999, 0, !- X,Y,Z Vertex 2 {m} 0, -4.99999999999999, 0, !- X,Y,Z Vertex 3 {m} 0, -4.99999999999999, 3.4; !- X,Y,Z Vertex 4 {m}FenestrationSurface:Detailed, Sub Surface 44, !- Name Window,
!- Surface Type EXT_WINDOW1,
!- Construction Name Surface 321,
!- Building Surface Name ,
!- Shading Control Name Window Property Frame And Divider 1, !- Frame and Divider Name ,
!- Multiplier ,
-2.8749990463257, -4.99999999999999, 2.5, !- X,Y,Z Vertex 1 {m} -2.8749990463257, -4.99999999999999, 0.999999999999999, !- X,Y,Z Vertex 2 {m} -0.8749990463257, -4.99999999999999, 0.999999999999999, !- X,Y,Z Vertex 3 {m}
-0.8749990463257, -4.99999999999999, 2.5; !- X,Y,Z Vertex 4 {m}BuildingSurface:Detailed, Surface 322, !- Name Wall,
NoSun,
!- Wind Exposure ,
-3.74999904632568, 0, 3.4, !- X,Y,Z Vertex 1 {m}
-3.74999904632568, 0, 0, !- X,Y,Z Vertex 2 {m}
-3.74999904632568, -4.99999999999999, 3.4; !- X,Y,Z Vertex 4 {m}BuildingSurface:Detailed, Surface 323, !- Name Wall,
NoSun,
!- Wind Exposure ,
!- Number of Vertices 0, 0, 3.4,
!- X,Y,Z Vertex 1 {m} 0, 0, 0,
-3.74999904632568, 0, 0, !- X,Y,Z Vertex 3 {m}
-3.74999904632568, 0, 3.4; !- X,Y,Z Vertex 4 {m}BuildingSurface:Detailed, Surface 324, !- Name Ceiling,
NoSun,
!- Wind Exposure ,
!- Number of Vertices 0, -4.99999999999999, 3.4, !- X,Y,Z Vertex 1 {m} 0, 0, 3.4,
-3.74999904632568, 0, 3.4, !- X,Y,Z Vertex 3 {m}
-3.74999904632568, -4.99999999999999, 3.4; !- X,Y,Z Vertex 4 {m}ZoneControl:Thermostat, B_2OG_4 Thermostat, !- Name B_2OG_4,
!- Zone or ZoneList Name B_2OG_4 Thermostat Schedule, !- Control Type Schedule Name
ThermostatSetpoint:DualSetpoint,
!- Control Object Type 1 Thermostat Setpoint Dual Setpoint 109; !- Control Name 1Schedule:Compact, B_2OG_4 Thermostat Schedule, !- Name B_2OG_4 Thermostat Schedule Type Limits, !- Schedule Type Limits Name Through: 12/31, !- Field 1 For: AllDays,
!- Field 2 Until: 24:00,
!- Field 3 4;
!- Field 4ScheduleTypeLimits, B_2OG_4 Thermostat Schedule Type Limits, !- Name 0,
!- Lower Limit Value {BasedOnField A3} 4,
!- Upper Limit Value {BasedOnField A3} DISCRETE;
!- Numeric TypeThermostatSetpoint:DualSetpoint,
Thermostat Setpoint Dual Setpoint 109, !- Name Schedule Heating,
!- Heating Setpoint Temperature Schedule Name Schedule Cooling;
!- Cooling Setpoint Temperature Schedule NameScheduleTypeLimits, Temperature 5,
!- Name ,
!- Lower Limit Value {BasedOnField A3} ,
!- Upper Limit Value {BasedOnField A3} Continuous,
!- Numeric Type temperature;
!- Unit TypeSchedule:Day:Interval, Schedule Day 1, !- Name
Temperature 5,
!- Schedule Type Limits Name No,
!- Interpolate to Timestep 24:00,
!- Time 1 {hh:mm} 22;
!- Value Until Time 1Schedule:Week:Daily,
Schedule:Week:Daily {069afb59-3b7b-42d8-a1ec-c8afd166cc97}, !- Name Schedule Day 1,
!- Sunday Schedule:Day Name Schedule Day 1, !- Monday Schedule:Day Name Schedule Day 1, !- Tuesday Schedule:Day Name Schedule Day 1, !- Wednesday Schedule:Day Name Schedule Day 1, !- Thursday Schedule:Day Name Schedule Day 1, !- Friday Schedule:Day Name Schedule Day 1, !- Saturday Schedule:Day Name Schedule Day 1, !- Holiday Schedule:Day Name Schedule Day 1, !- SummerDesignDay Schedule:Day Name
Schedule Day 1,
!- WinterDesignDay Schedule:Day Name
Schedule Day 1,
!- CustomDay1 Schedule:Day Name
Schedule Day 1;
!- CustomDay2 Schedule:Day NameSchedule:Year, Schedule Heating,
!- Name Temperature 5,
Schedule:Week:Daily {069afb59-3b7b-42d8-a1ec-c8afd166cc97}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
!- End Day 1Schedule:Day:Interval, Schedule Day 5, !- Name
Temperature 5,
!- Time 1 {hh:mm} 25;
Schedule:Week:Daily {2a40792a-05eb-473a-a066-793092129d81}, !- Name Schedule Day 5,
!- Sunday Schedule:Day Name Schedule Day 5, !- Monday Schedule:Day Name Schedule Day 5, !- Tuesday Schedule:Day Name Schedule Day 5, !- Wednesday Schedule:Day Name Schedule Day 5, !- Thursday Schedule:Day Name Schedule Day 5, !- Friday Schedule:Day Name Schedule Day 5, !- Saturday Schedule:Day Name Schedule Day 5, !- Holiday Schedule:Day Name Schedule Day 5, !- SummerDesignDay Schedule:Day Name
Schedule Day 5,
Schedule Day 5,
Schedule Day 5;
!- CustomDay2 Schedule:Day NameSchedule:Year, Schedule Cooling,
Schedule:Week:Daily {2a40792a-05eb-473a-a066-793092129d81}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
!- End Day 1ZoneControl:Humidistat, Zone Control Humidistat 38, !- Name
B_2OG_4,
!- Zone Name Schedule Humidification, !- Humidifying Relative Humidity Setpoint Schedule Name Schedule Dehumidification; !- Dehumidifying Relative Humidity Setpoint Schedule NameScheduleTypeLimits, Percent,
!- Name 0,
!- Lower Limit Value {BasedOnField A3} 100,
!- Numeric Type percent;
!- Unit TypeSchedule:Day:Interval, Schedule Day 3, !- Name
Percent,
!- Time 1 {hh:mm} 40;
Schedule:Week:Daily {6d469944-3b66-4ae7-8bf8-af20a7d65149}, !- Name Schedule Day 3,
!- Sunday Schedule:Day Name Schedule Day 3, !- Monday Schedule:Day Name Schedule Day 3, !- Tuesday Schedule:Day Name Schedule Day 3, !- Wednesday Schedule:Day Name Schedule Day 3, !- Thursday Schedule:Day Name Schedule Day 3, !- Friday Schedule:Day Name Schedule Day 3, !- Saturday Schedule:Day Name Schedule Day 3, !- Holiday Schedule:Day Name Schedule Day 3, !- SummerDesignDay Schedule:Day Name
Schedule Day 3,
Schedule Day 3,
Schedule Day 3;
!- CustomDay2 Schedule:Day NameSchedule:Year, Schedule Humidification, !- Name Percent,
Schedule:Week:Daily {6d469944-3b66-4ae7-8bf8-af20a7d65149}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
!- End Day 1Schedule:Day:Interval, Schedule Day 6, !- Name
Percent,
!- Time 1 {hh:mm} 60;
Schedule:Week:Daily {0a109771-d79b-4b99-9247-517ee72b14dc}, !- Name Schedule Day 6,
!- Sunday Schedule:Day Name Schedule Day 6, !- Monday Schedule:Day Name Schedule Day 6, !- Tuesday Schedule:Day Name Schedule Day 6, !- Wednesday Schedule:Day Name Schedule Day 6, !- Thursday Schedule:Day Name Schedule Day 6, !- Friday Schedule:Day Name Schedule Day 6, !- Saturday Schedule:Day Name Schedule Day 6, !- Holiday Schedule:Day Name Schedule Day 6, !- SummerDesignDay Schedule:Day Name
Schedule Day 6,
Schedule Day 6,
Schedule Day 6;
!- CustomDay2 Schedule:Day NameSchedule:Year, Schedule Dehumidification, !- Name Percent,
Schedule:Week:Daily {0a109771-d79b-4b99-9247-517ee72b14dc}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
!- End Day 1HVACTemplate:Zone:IdealLoadsAirSystem, B_2OG_4,
!- Zone Name ,
!- Template Thermostat Name ,
!- System Availability Schedule Name
!- Maximum Heating Supply Air Temperature {C} ,
!- Minimum Cooling Supply Air Temperature {C} ,
!- Maximum Heating Supply Air Humidity Ratio {kgWater/kgDryAir} ,
!- Minimum Cooling Supply Air Humidity Ratio {kgWater/kgDryAir} ,
!- Heating Limit ,
!- Maximum Heating Air Flow Rate {m3/s} ,
!- Maximum Sensible Heating Capacity {W} ,
!- Cooling Limit ,
!- Maximum Cooling Air Flow Rate {m3/s} ,
!- Maximum Total Cooling Capacity {W} ,
!- Heating Availability Schedule Name ,
!- Cooling Availability Schedule Name ,
!- Dehumidification Control Type ,
!- Cooling Sensible Heat Ratio {dimensionless} ,
!- Dehumidification Setpoint {percent} ,
!- Humidification Control Type ,
!- Humidification Setpoint {percent}
!- Outdoor Air Method ,
!- Outdoor Air Flow Rate per Person {m3/s} ,
!- Outdoor Air Flow Rate per Zone Floor Area {m3/s-m2} ,
!- Outdoor Air Flow Rate per Zone {m3/s} ,
!- Design Specification Outdoor Air Object Name ;
!- Demand Controlled Ventilation TypeSizing:Zone, B_2OG_4,
SupplyAirTemperature,
!- Zone Cooling Design Supply Air Temperature Input Method 14,
!- Zone Cooling Design Supply Air Temperature {C} ,
!- Zone Cooling Design Supply Air Temperature Difference {deltaC}
!- Zone Heating Design Supply Air Temperature Input Method 40,
!- Zone Heating Design Supply Air Temperature {C} ,
!- Zone Heating Design Supply Air Temperature Difference {deltaC} 0.0085, !- Zone Cooling Design Supply Air Humidity Ratio {kgWater/kgDryAir} 0.008, !- Zone Heating Design Supply Air Humidity Ratio {kgWater/kgDryAir}
Office Ventilation,
!- Design Specification Outdoor Air Object Name ,
!- Zone Heating Sizing Factor ,
!- Zone Cooling Sizing Factor
DesignDay,
!- Cooling Design Air Flow Method 0, !- Cooling Design Air Flow Rate {m3/s} 0.000762, !- Cooling Minimum Air Flow per Zone Floor Area {m3/s-m2} 0,
!- Cooling Minimum Air Flow {m3/s}
0,
!- Cooling Minimum Air Flow Fraction
DesignDay,
!- Heating Design Air Flow Method 0, !- Heating Design Air Flow Rate {m3/s} 0.002032, !- Heating Maximum Air Flow per Zone Floor Area {m3/s-m2} 0.1415762, !- Heating Maximum Air Flow {m3/s} 0.3, !- Heating Maximum Air Flow Fraction
B_2OG_4 Design Spec Zone Air Dist;
!- Design Specification Zone Air Distribution Object NameDesignSpecification:ZoneAirDistribution, B_2OG_4 Design Spec Zone Air Dist,
!- Name 1,
!- Zone Air Distribution Effectiveness in Cooling Mode {dimensionless} 1;
!- Zone Air Distribution Effectiveness in Heating Mode {dimensionless}DesignSpecification:OutdoorAir,
Office Ventilation,
!- Name Sum,
!- Outdoor Air Method 0.007079211648, !- Outdoor Air Flow per Person {m3/s-person} 0,
!- Outdoor Air Flow per Zone Floor Area {m3/s-m2} 0,
!- Outdoor Air Flow per Zone {m3/s} 1.5, !- Outdoor Air Flow Air Changes per Hour {1/hr} always on;
!- Outdoor Air Flow Rate Fraction Schedule NameZoneVentilation:DesignFlowRate,
B_2OG_4 Ventilation per Person,
!- Name B_2OG_4,
!- Zone or ZoneList Name always on, !- Schedule Name Flow/Person,
!- Design Flow Rate Calculation Method ,
!- Design Flow Rate {m3/s} ,
!- Flow Rate per Zone Floor Area {m3/s-m2} 0.007079211648, !- Flow Rate per Person {m3/s-person} ,
!- Air Changes per Hour {1/hr} ,
!- Ventilation Type ,
!- Fan Pressure Rise {Pa} ,
!- Fan Total Efficiency ,
!- Constant Term Coefficient ,
!- Temperature Term Coefficient ,
!- Velocity Term Coefficient ;
!- Velocity Squared Term CoefficientSchedule:Constant, Always_On,
!- Name ,
!- Schedule Type Limits Name 1;
!- Hourly ValueZoneVentilation:DesignFlowRate,
B_2OG_4 Ventilation Air Changes per Hour, !- Name B_2OG_4,
!- Zone or ZoneList Name Always_On, !- Schedule Name AirChanges/Hour,
!- Flow Rate per Zone Floor Area {m3/s-m2} ,
!- Flow Rate per Person {m3/s-person} 1.5, !- Air Changes per Hour {1/hr} ,
!- Velocity Squared Term CoefficientSimulationControl, Yes,
!- Do Zone Sizing Calculation No,
!- Do System Sizing Calculation No, !- Do Plant Sizing Calculation Yes, !- Run Simulation for Sizing Periods
Yes;
!- Run Simulation for Weather File Run PeriodsConvergenceLimits, 1;
!- Minimum System Timestep {minutes}HeatBalanceAlgorithm,
ConductionTransferFunction,
!- Algorithm 200;
!- Surface Temperature Upper Limit {C}RunPeriod, Run Period 1,
!- Name 1,
!- Begin Month 1,
!- Begin Day of Month 12,
!- End Month 31,
!- End Day of Month Sunday,
!- Day of Week for Start Day No,
!- Use Weather File Holidays and Special Days No,
!- Use Weather File Daylight Saving Period No,
!- Apply Weekend Holiday Rule Yes,
!- Use Weather File Rain Indicators
Yes,
!- Use Weather File Snow Indicators
1;
!- Number of Times Runperiod to be RepeatedShadowCalculation,
AverageOverDaysInFrequency,
!- Calculation Method 20,
!- Calculation Frequency 15000;
!- Maximum Figures in Shadow Overlap CalculationsSurfaceConvectionAlgorithm:Inside,
TARP;
!- AlgorithmSurfaceConvectionAlgorithm:Outside,
DOE-2;
!- AlgorithmTimestep, 4;
!- Number of Timesteps per HourSizing:Parameters, 1.25, !- Heating Sizing Factor 1.15; !- Cooling Sizing Factor
ZoneAirHeatBalanceAlgorithm,
ThirdOrderBackwardDifference;
!- AlgorithmProgramControl, 1;
!- Number of Threads AllowedGlobalGeometryRules,
UpperLeftCorner,
!- Starting Vertex Position
Counterclockwise,
!- Vertex Entry Direction Relative, !- Coordinate System Relative,
!- Daylighting Reference Point Coordinate System Relative;
!- Rectangular Surface Coordinate SystemMaterial, BET_160,
!- Name Smooth,
!- Roughness 0.16, !- Thickness {m} 2.1, !- Conductivity {W/m-K} 2200,
!- Density {kg/m3} 1000,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, BET_200,
!- Name Smooth,
!- Roughness 0.2, !- Thickness {m} 2.1, !- Conductivity {W/m-K} 2200,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, DAEMA_133,
!- Name Smooth,
!- Roughness 0.133, !- Thickness {m} 0.048, !- Conductivity {W/m-K} 60,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, DAEMA_162,
!- Name Smooth,
!- Roughness 0.162, !- Thickness {m} 0.048, !- Conductivity {W/m-K} 60,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, DAEMA_167,
!- Name Smooth,
!- Roughness 0.167, !- Thickness {m} 0.048, !- Conductivity {W/m-K} 60,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, DAEMA_173,
!- Name Smooth,
!- Roughness 0.173, !- Thickness {m} 0.048, !- Conductivity {W/m-K} 60,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, DAEMA_300,
!- Name Smooth,
!- Roughness 0.3, !- Thickness {m} 0.048, !- Conductivity {W/m-K} 60,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, DAEMM_121,
!- Name Smooth,
!- Roughness 0.121, !- Thickness {m} 0.04, !- Conductivity {W/m-K} 60,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, DAEMM_305,
!- Name Smooth,
!- Roughness 0.305, !- Thickness {m} 0.04, !- Conductivity {W/m-K} 60,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, ESTR_050,
!- Name Smooth,
!- Roughness 0.05, !- Thickness {m} 1.4, !- Conductivity {W/m-K} 2000,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, GIPS_013,
!- Name Smooth,
!- Roughness 0.013, !- Thickness {m} 0.21, !- Conductivity {W/m-K} 900,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, HOLZ_020,
!- Name Smooth,
!- Roughness 0.02, !- Thickness {m} 0.13, !- Conductivity {W/m-K} 600,
!- Density {kg/m3} 2100,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, HOLZ_030,
!- Name Smooth,
!- Roughness 0.03, !- Thickness {m} 0.13, !- Conductivity {W/m-K} 600,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, KST_175,
!- Name Smooth,
!- Roughness 0.175, !- Thickness {m} 0.99, !- Conductivity {W/m-K} 1600,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, MIWO_030,
!- Name Smooth,
!- Roughness 0.03, !- Thickness {m} 0.04, !- Conductivity {W/m-K} 60,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, MIWO_100,
!- Name Smooth,
!- Roughness 0.1, !- Thickness {m} 0.04, !- Conductivity {W/m-K} 60,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, PUTZ_015,
!- Name Smooth,
!- Roughness 0.015, !- Thickness {m} 0.7, !- Conductivity {W/m-K} 1400,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial, TEPP_005,
!- Name Smooth,
!- Roughness 0.005, !- Thickness {m} 0.08, !- Conductivity {W/m-K} 700,
!- Density {kg/m3} 1300,
!- Specific Heat {J/kg-K} 0.9, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial:AirGap, F04 Wall air space resistance, !- Name 0.15; !- Thermal Resistance {m2-K/W}
Material:AirGap, F05 Ceiling air space resistance, !- Name 0.18; !- Thermal Resistance {m2-K/W}
Material, Air Wall Material,
!- Name MediumSmooth,
!- Roughness 0.01, !- Thickness {m} 0.6, !- Conductivity {W/m-K} 800,
!- Specific Heat {J/kg-K} 0.95, !- Thermal Absorptance 0.7, !- Solar Absorptance 0.7; !- Visible AbsorptanceMaterial:NoMass, CP02 CARPET PAD,
!- Name Smooth,
!- Roughness 0.1, !- Thermal Resistance {m2-K/W} 0.9, !- Thermal Absorptance 0.8, !- Solar Absorptance 0.8; !- Visible AbsorptanceWindowMaterial:Blind, Window Material Blind 1, !- Name Horizontal,
!- Slat Orientation 0.025, !- Slat Width {m} 0.01875, !- Slat Separation {m} 0.001, !- Slat Thickness {m} 45,
!- Slat Angle {deg} 221,
!- Slat Conductivity {W/m-K} 0,
!- Slat Beam Solar Transmittance 0.5, !- Front Side Slat Beam Solar Reflectance 0.5, !- Back Side Slat Beam Solar Reflectance 0,
!- Slat Diffuse Solar Transmittance 0.5, !- Front Side Slat Diffuse Solar Reflectance 0.5, !- Back Side Slat Diffuse Solar Reflectance 0,
!- Slat Beam Visible Transmittance 0.5, !- Front Side Slat Beam Visible Reflectance 0.5, !- Back Side Slat Beam Visible Reflectance 0,
!- Slat Diffuse Visible Transmittance 0.5, !- Front Side Slat Diffuse Visible Reflectance 0.5, !- Back Side Slat Diffuse Visible Reflectance 0,
!- Slat Infrared Hemispherical Transmittance 0.9, !- Front Side Slat Infrared Hemispherical Emissivity 0.9, !- Back Side Slat Infrared Hemispherical Emissivity 0.05, !- Blind to Glass Distance {m} 0.5, !- Blind Top Opening Multiplier 0.5, !- Blind Bottom Opening Multiplier 0.5, !- Blind Left Side Opening Multiplier 0.5, !- Blind Right Side Opening Multiplier 0,
!- Minimum Slat Angle {deg} 180;
!- Maximum Slat Angle {deg}WindowMaterial:Gas, 16mm Argon,
!- Name Argon,
!- Gas Type 0.016; !- Thickness {m}WindowMaterial:Glazing, Clear 4mm,
!- Name SpectralAverage,
!- Optical Data Type ,
!- Window Glass Spectral Data Set Name 0.00299999999999999, !- Thickness {m} 0.837, !- Solar Transmittance at Normal Incidence 0.075, !- Front Side Solar Reflectance at Normal Incidence 0,
!- Back Side Solar Reflectance at Normal Incidence 0.898, !- Visible Transmittance at Normal Incidence 0.081, !- Front Side Visible Reflectance at Normal Incidence 0,
!- Back Side Visible Reflectance at Normal Incidence 0,
!- Infrared Transmittance at Normal Incidence 0.84, !- Front Side Infrared Hemispherical Emissivity 0.84, !- Back Side Infrared Hemispherical Emissivity 0.9, !- Conductivity {W/m-K} 1,
!- Dirt Correction Factor for Solar and Visible Transmittance No;
!- Solar DiffusingWindowMaterial:Screen, Window Material Screen 1, !- Name ModelAsDiffuse,
!- Reflected Beam Transmittance Accounting Method 0.08, !- Diffuse Solar Reflectance {dimensionless} 0.08, !- Diffuse Visible Reflectance {dimensionless} 0.9, !- Thermal Hemispherical Emissivity {dimensionless} 221,
!- Conductivity {W/m-K} 0.00157, !- Screen Material Spacing {m} 0.000381, !- Screen Material Diameter {m} 0.025, !- Screen to Glass Distance {m} 0,
!- Top Opening Multiplier {dimensionless} 0,
!- Bottom Opening Multiplier {dimensionless} 0,
!- Left Side Opening Multiplier {dimensionless} 0,
!- Right Side Opening Multiplier {dimensionless} 0;
!- Angle of Resolution for Screen Transmittance Output Map {deg}WindowMaterial:Shade, Window Material Shade 1, !- Name 0.4, !- Solar Transmittance {dimensionless} 0.5, !- Solar Reflectance {dimensionless} 0.4, !- Visible Transmittance {dimensionless} 0.5, !- Visible Reflectance {dimensionless} 0.9, !- Infrared Hemispherical Emissivity {dimensionless} 0,
!- Infrared Transmittance {dimensionless} 0.005, !- Thickness {m} 0.1, !- Conductivity {W/m-K} 0.05, !- Shade to Glass Distance {m} 0,
!- Top Opening Multiplier 0,
!- Bottom Opening Multiplier 0,
!- Left-Side Opening Multiplier 0,
!- Right-Side Opening Multiplier 0; !- Airflow Permeability {dimensionless}WindowProperty:ShadingControl , CONTROL ON INCIDENT SOLAR, !- Name of Shading Control ExteriorShade , !- Shading Type EXT_WINDOW1 WITH SHADE, !- Name of construction with shading device OnIfHighSolarOnWindow , !- Shading Control Type , !- Schedule name 50.0, !- Setpoint {W/m2} NO, !- Shading Control Is Scheduled NO, !- Glare Control Is Active , !- Material Name of Shading Device , !- Type of Slat Angle Control for Blinds ; !- Slat Angle Schedule Name
WindowProperty:FrameAndDivider,
!- Name 0.05081016, !- Frame Width {m} 0.05081016, !- Frame Outside Projection {m} 0.05081016, !- Frame Inside Projection {m} 0.0162, !- Frame Conductance {W/m2-K} 1,
!- Ratio of Frame-Edge Glass Conductance to Center-Of-Glass Conductance 0.7, !- Frame Solar Absorptance 0.7, !- Frame Visible Absorptance 0.9, !- Frame Thermal Hemispherical Emissivity DividedLite,
!- Divider Type 0,
!- Divider Width {m} 0,
!- Number of Horizontal Dividers 0, !- Number of Vertical Dividers 0,
!- Divider Outside Projection {m} 0, !- Divider Inside Projection {m} 0, !- Divider Conductance {W/m2-K} 1,
!- Ratio of Divider-Edge Glass Conductance to Center-Of-Glass Conductance 0,
!- Divider Solar Absorptance 0,
!- Divider Visible Absorptance 0.9, !- Divider Thermal Hemispherical Emissivity 0,
!- Outside Reveal Solar Absorptance
0,
!- Inside Sill Depth {m} 0,
!- Inside Sill Solar Absorptance 0, !- Inside Reveal Depth {m} 0;
!- Inside Reveal Solar AbsorptanceConstruction, ADJ_CEILING,
!- Name TEPP_005,
!- Layer 1 ESTR_050,
!- Layer 2 MIWO_030,
!- Layer 3 BET_160,
!- Layer 4 PUTZ_015;
!- Layer 5Construction, ADJ_WALL,
!- Name GIPS_013,
!- Layer 1 MIWO_100,
!- Layer 2 GIPS_013;
!- Layer 3Construction, BND_CEILING,
!- Name HOLZ_030,
!- Layer 1 DAEMA_300,
!- Layer 2 BET_160,
!- Layer 3 PUTZ_015;
!- Layer 4Construction, BND_FLOOR,
!- Name GIPS_013,
!- Layer 1 DAEMA_133,
!- Layer 2 BET_160,
!- Layer 3 MIWO_030,
!- Layer 4 ESTR_050,
!- Layer 5 TEPP_005;
!- Layer 6Construction, BND_WALL,
!- Name GIPS_013,
!- Layer 1 DAEMA_173,
!- Layer 2 KST_175,
!- Layer 4Construction, EXT_FLOOR,
!- Name DAEMA_162,
!- Layer 1 BET_160,
!- Layer 3 ESTR_050,
!- Layer 4 TEPP_005;
!- Layer 5Construction, EXT_ROOF,
!- Name HOLZ_020,
!- Layer 1 DAEMM_305,
!- Layer 2 BET_160,
!- Layer 4Construction, EXT_WALL,
!- Name HOLZ_020,
!- Layer 1 DAEMA_167,
!- Layer 2 KST_175,
!- Layer 4Construction, EXT_WINDOW1,
!- Name Clear 4mm,
!- Layer 2 16mm Argon,
!- Layer 3 Clear 4mm;
!- Layer 4Construction, EXT_WINDOW1 WITH SHADE, !- Name Window Material Shade 1,
!- Layer 1 Clear 4mm,
!- Layer 4Construction, GROUND_FLOOR,
!- Name BET_200,
!- Layer 1 DAEMM_121,
!- Layer 2 ESTR_050,
!- Layer 3 TEPP_005;
!- Layer 4ScheduleTypeLimits, ActivityLevel,
!- Name 0,
!- Numeric Type activitylevel;
!- Unit TypeScheduleTypeLimits, ActivityLevel 12, !- Name 0, !- Lower Limit Value {BasedOnField A3} ,
!- Unit TypeScheduleTypeLimits, ActivityLevel 13, !- Name 0, !- Lower Limit Value {BasedOnField A3} ,
!- Unit TypeScheduleTypeLimits, ActivityLevel 5, !- Name 0,
!- Unit TypeScheduleTypeLimits, Capacity,
!- Name 0,
!- Numeric Type capacity;
!- Unit TypeScheduleTypeLimits, Any Number;
!- NameScheduleTypeLimits, ControlMode,
!- Name 0,
!- Lower Limit Value {BasedOnField A3} 1,
!- Upper Limit Value {BasedOnField A3} Discrete,
!- Numeric Type controlmode;
DeltaTemperature,
!- Name ,
!- Numeric Type deltatemperature;
!- Unit TypeScheduleTypeLimits, Dimensionless,
!- Name ,
!- Upper Limit Value {BasedOnField A3} Continuous;
!- Numeric TypeScheduleTypeLimits, Dimensionless 1, !- Name 0,
!- Numeric Type dimensionless;
!- Unit TypeScheduleTypeLimits, Fraction,
!- Name 0,
!- Upper Limit Value {BasedOnField A3} CONTINUOUS;
!- Numeric TypeScheduleTypeLimits, Fractional,
!- Name 0,
LinearPowerDensity,
!- Name 0,
!- Numeric Type linearpowerdensity; !- Unit TypeScheduleTypeLimits, OnOff,
!- Name 0,
!- Numeric Type availability;
!- Unit TypeScheduleTypeLimits, Temperature 11, !- Name ,
!- Unit TypeScheduleTypeLimits, Temperature 3,
!- Name ,
!- Unit TypeScheduleTypeLimits, Temperature 36, !- Name ,
!- Unit TypeScheduleTypeLimits, Temperature 37, !- Name ,
!- Unit TypeScheduleTypeLimits, Temperature 4,
!- Name ,
!- Unit TypeScheduleTypeLimits, Velocity,
!- Name 0,
!- Numeric Type velocity;
VolumetricFlowRate,
!- Name 0,
!- Numeric Type volumetricflowrate; !- Unit TypeSchedule:Day:Interval, Medium Office Activity Default Schedule, !- Name
ActivityLevel 13,
!- Time 1 {hh:mm} 120;
!- Value Until Time 1Schedule:Day:Interval, Medium Office Activity Summer Design Day, !- Name
ActivityLevel 13,
!- Value Until Time 1Schedule:Day:Interval, Medium Office Activity Winter Design Day, !- Name
ActivityLevel 13,
!- Value Until Time 1Schedule:Day:Interval, Medium Office Bldg Equip Default Schedule, !- Name
Fraction,
!- Interpolate to Timestep 08:00,
!- Time 1 {hh:mm} 0.4, !- Value Until Time 1 12:00,
!- Time 2 {hh:mm} 0.9, !- Value Until Time 2 13:00,
!- Time 3 {hh:mm} 0.8, !- Value Until Time 3 17:00,
!- Time 4 {hh:mm} 0.9, !- Value Until Time 4 18:00,
!- Time 5 {hh:mm} 0.8, !- Value Until Time 5 20:00,
!- Time 6 {hh:mm} 0.6, !- Value Until Time 6 22:00,
!- Time 7 {hh:mm} 0.5, !- Value Until Time 7 24:00,
!- Time 8 {hh:mm} 0.4; !- Value Until Time 8Schedule:Day:Interval, Medium Office Bldg Equip Rule 1 Day Schedule, !- Name Fraction,
!- Time 1 {hh:mm} 0.3; !- Value Until Time 1Schedule:Day:Interval, Medium Office Bldg Equip Rule 2 Day Schedule, !- Name Fraction,
!- Interpolate to Timestep 06:00,
!- Time 1 {hh:mm} 0.3, !- Value Until Time 1 08:00,
!- Time 2 {hh:mm} 0.4, !- Value Until Time 2 14:00,
!- Time 3 {hh:mm} 0.5, !- Value Until Time 3 17:00,
!- Time 4 {hh:mm} 0.35, !- Value Until Time 4 24:00,
!- Time 5 {hh:mm} 0.3; !- Value Until Time 5Schedule:Day:Interval, Medium Office Bldg Equip Summer Design Day, !- Name Fraction,
!- Time 1 {hh:mm} 1;
!- Value Until Time 1Schedule:Day:Interval, Medium Office Bldg Equip Winter Design Day, !- Name Fraction,
!- Time 1 {hh:mm} 0;
!- Value Until Time 1Schedule:Day:Interval, Medium Office Bldg Occ Default Schedule, !- Name
Fraction,
!- Time 1 {hh:mm} 0,
!- Value Until Time 1 07:00,
!- Time 2 {hh:mm} 0.1, !- Value Until Time 2 08:00,
!- Time 3 {hh:mm} 0.2, !- Value Until Time 3 12:00,
!- Time 4 {hh:mm} 0.95, !- Value Until Time 4 13:00,
!- Time 5 {hh:mm} 0.5, !- Value Until Time 5 17:00,
!- Time 6 {hh:mm} 0.95, !- Value Until Time 6 18:00,
!- Time 7 {hh:mm} 0.7, !- Value Until Time 7 20:00,
!- Time 8 {hh:mm} 0.4, !- Value Until Time 8 22:00,
!- Time 9 {hh:mm} 0.1, !- Value Until Time 9 24:00,
!- Time 10 {hh:mm} 0.05; !- Value Until Time 10Schedule:Day:Interval, Medium Office Bldg Occ Rule 1 Day Schedule, !- Name Fraction,
!- Value Until Time 1Schedule:Day:Interval, Medium Office Bldg Occ Rule 2 Day Schedule, !- Name Fraction,
!- Time 2 {hh:mm} 0.1, !- Value Until Time 2 14:00,
!- Time 4 {hh:mm} 0.1, !- Value Until Time 4 24:00,
!- Time 5 {hh:mm} 0;
!- Value Until Time 5Schedule:Day:Interval, Medium Office Bldg Occ Summer Design Day, !- Name
Fraction,
!- Value Until Time 1 22:00,
!- Time 2 {hh:mm} 1,
!- Value Until Time 2 24:00,
!- Time 3 {hh:mm} 0.05; !- Value Until Time 3Schedule:Day:Interval, Medium Office Bldg Occ Winter Design Day, !- Name
Fraction,
!- Value Until Time 1Schedule:Day:Interval, Medium Office Infil Quarter On Default Schedule, !- Name Fraction,
!- Time 1 {hh:mm} 1,
!- Time 2 {hh:mm} 0.25, !- Value Until Time 2 24:00,
!- Time 3 {hh:mm} 1;
!- Value Until Time 3Schedule:Day:Interval, Medium Office Infil Quarter On Rule 1 Day Schedule, !- Name Fraction,
!- Value Until Time 1Schedule:Day:Interval, Medium Office Infil Quarter On Rule 2 Day Schedule, !- Name Fraction,
!- Value Until Time 1 18:00,
!- Value Until Time 3Schedule:Day:Interval, Medium Office Infil Quarter On Summer Design Day, !- Name Fraction,
!- Value Until Time 3Schedule:Day:Interval, Medium Office Infil Quarter On Winter Design Day, !- Name Fraction,
!- Value Until Time 3Schedule:Day:Interval, Office Activity Default Schedule, !- Name ActivityLevel,
!- Time 1 {hh:mm} 132;
!- Value Until Time 1Schedule:Day:Interval, Office Activity Summer Design Day, !- Name ActivityLevel,
!- Value Until Time 1Schedule:Day:Interval, Office Activity Winter Design Day, !- Name ActivityLevel,
!- Value Until Time 1Schedule:Day:Interval, Office Bldg Equip Default Schedule, !- Name
Fraction,
!- Time 8 {hh:mm} 0.4; !- Value Until Time 8Schedule:Day:Interval, Office Bldg Equip Rule 1 Day Schedule, !- Name
Fraction,
!- Time 1 {hh:mm} 0.3; !- Value Until Time 1Schedule:Day:Interval, Office Bldg Equip Rule 2 Day Schedule, !- Name
Fraction,
!- Time 5 {hh:mm} 0.3; !- Value Until Time 5Schedule:Day:Interval, Office Bldg Equip Summer Design Day, !- Name
Fraction,
!- Value Until Time 1Schedule:Day:Interval, Office Bldg Equip Winter Design Day, !- Name
Fraction,
!- Value Until Time 1Schedule:Day:Interval, Office Bldg Light Default Schedule, !- Name
Fraction,
!- Interpolate to Timestep 05:00,
!- Time 1 {hh:mm} 0.05, !- Value Until Time 1 07:00,
!- Time 3 {hh:mm} 0.3, !- Value Until Time 3 17:00,
!- Time 5 {hh:mm} 0.7, !- Value Until Time 5 20:00,
!- Time 6 {hh:mm} 0.5, !- Value Until Time 6 22:00,
!- Time 7 {hh:mm} 0.3, !- Value Until Time 7 23:00,
!- Time 8 {hh:mm} 0.1, !- Value Until Time 8 24:00,
!- Time 9 {hh:mm} 0.05; !- Value Until Time 9Schedule:Day:Interval, Office Bldg Light Rule 1 Day Schedule, !- Name
Fraction,
!- Time 1 {hh:mm} 0.05; !- Value Until Time 1Schedule:Day:Interval, Office Bldg Light Rule 2 Day Schedule, !- Name
Fraction,
!- Time 1 {hh:mm} 0.05, !- Value Until Time 1 08:00,
!- Time 4 {hh:mm} 0.15, !- Value Until Time 4 24:00,
!- Time 5 {hh:mm} 0.05; !- Value Until Time 5Schedule:Day:Interval, Office Bldg Light Summer Design Day, !- Name
Fraction,
!- Value Until Time 1Schedule:Day:Interval, Office Bldg Light Winter Design Day, !- Name
Fraction,
!- Value Until Time 1Schedule:Day:Interval, Office Bldg Occ Default Schedule 1, !- Name
Fraction,
!- Time 2 {hh:mm} 0.100000001490116, !- Value Until Time 2 08:00,
!- Time 3 {hh:mm} 0.200000002980232, !- Value Until Time 3 20:00,
!- Time 4 {hh:mm} 0.400000005960464, !- Value Until Time 4 22:00,
!- Time 5 {hh:mm} 0.100000001490116, !- Value Until Time 5 24:00,
!- Time 6 {hh:mm} 0.0500000007450581; !- Value Until Time 6Schedule:Day:Interval, Office Bldg Occ Rule 1 Day Schedule 1, !- Name
Fraction,
!- Value Until Time 1Schedule:Day:Interval, Office Bldg Occ Rule 2 Day Schedule 1, !- Name
Fraction,
!- Time 2 {hh:mm} 0.100000001490116, !- Value Until Time 2 14:00,
!- Time 3 {hh:mm} 0.25, !- Value Until Time 3 17:00,
!- Time 4 {hh:mm} 0.100000001490116, !- Value Until Time 4 24:00,
!- Value Until Time 5Schedule:Day:Interval, Office Bldg Occ Summer Design Day 1, !- Name
Fraction,
!- Time 3 {hh:mm} 0.05; !- Value Until Time 3Schedule:Day:Interval, Office Bldg Occ Winter Design Day 1, !- Name
Fraction,
!- Value Until Time 1Schedule:Day:Interval, Office Infil Quarter On Default Schedule, !- Name
Fraction,
!- Value Until Time 3Schedule:Day:Interval, Office Infil Quarter On Rule 1 Day Schedule, !- Name Fraction,
!- Value Until Time 1Schedule:Day:Interval, Office Infil Quarter On Rule 2 Day Schedule, !- Name Fraction,
!- Value Until Time 3Schedule:Day:Interval, Office Infil Quarter On Summer Design Day, !- Name Fraction,
!- Value Until Time 3Schedule:Day:Interval, Office Infil Quarter On Winter Design Day, !- Name Fraction,
!- Value Until Time 3Schedule:Day:Interval, Schedule Day 2, !- Name
OnOff,
!- Value Until Time 1Schedule:Day:Interval, Schedule Day 4, !- Name
ActivityLevel,
!- Time 1 {hh:mm} 100;
Schedule:Week:Daily {ddb9f058-d4b4-496a-8e27-cc9d3e64612e}, !- Name Schedule Day 2,
!- Sunday Schedule:Day Name Schedule Day 2, !- Monday Schedule:Day Name Schedule Day 2, !- Tuesday Schedule:Day Name Schedule Day 2, !- Wednesday Schedule:Day Name Schedule Day 2, !- Thursday Schedule:Day Name Schedule Day 2, !- Friday Schedule:Day Name Schedule Day 2, !- Saturday Schedule:Day Name Schedule Day 2, !- Holiday Schedule:Day Name Schedule Day 2, !- SummerDesignDay Schedule:Day Name
Schedule Day 2,
Schedule Day 2,
Schedule Day 2;
!- CustomDay2 Schedule:Day NameSchedule:Year, always on,
!- Name OnOff,
Schedule:Week:Daily {ddb9f058-d4b4-496a-8e27-cc9d3e64612e}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
!- End Day 1Schedule:Week:Daily,
Schedule:Week:Daily {33fd4363-8266-4b4a-ad94-3a0f543d63da}, !- Name Medium Office Activity Default Schedule, !- Sunday Schedule:Day Name Medium Office Activity Default Schedule, !- Monday Schedule:Day Name Medium Office Activity Default Schedule, !- Tuesday Schedule:Day Name Medium Office Activity Default Schedule, !- Wednesday Schedule:Day Name Medium Office Activity Default Schedule, !- Thursday Schedule:Day Name Medium Office Activity Default Schedule, !- Friday Schedule:Day Name Medium Office Activity Default Schedule, !- Saturday Schedule:Day Name Medium Office Activity Default Schedule, !- Holiday Schedule:Day Name Medium Office Activity Summer Design Day, !- SummerDesignDay Schedule:Day Name
Medium Office Activity Winter Design Day, !- WinterDesignDay Schedule:Day Name Medium Office Activity Default Schedule, !- CustomDay1 Schedule:Day Name Medium Office Activity Default Schedule; !- CustomDay2 Schedule:Day NameSchedule:Year, Medium Office Activity, !- Name
ActivityLevel 13,
Schedule:Week:Daily {33fd4363-8266-4b4a-ad94-3a0f543d63da}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
Schedule:Week:Daily {8ea0c07e-bda5-4e91-9522-2cd515cfd03a}, !- Name Medium Office Bldg Equip Rule 1 Day Schedule, !- Sunday Schedule:Day Name Medium Office Bldg Equip Default Schedule, !- Monday Schedule:Day Name Medium Office Bldg Equip Default Schedule, !- Tuesday Schedule:Day Name Medium Office Bldg Equip Default Schedule, !- Wednesday Schedule:Day Name Medium Office Bldg Equip Default Schedule, !- Thursday Schedule:Day Name Medium Office Bldg Equip Default Schedule, !- Friday Schedule:Day Name Medium Office Bldg Equip Rule 2 Day Schedule, !- Saturday Schedule:Day Name Medium Office Bldg Equip Default Schedule, !- Holiday Schedule:Day Name Medium Office Bldg Equip Summer Design Day, !- SummerDesignDay Schedule:Day Name
Medium Office Bldg Equip Winter Design Day, !- WinterDesignDay Schedule:Day Name Medium Office Bldg Equip Default Schedule, !- CustomDay1 Schedule:Day Name Medium Office Bldg Equip Default Schedule; !- CustomDay2 Schedule:Day NameSchedule:Year, Medium Office Bldg Equip, !- Name
Fraction,
Schedule:Week:Daily {8ea0c07e-bda5-4e91-9522-2cd515cfd03a}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
Schedule:Week:Daily {dafbcefd-3940-41b9-a8ac-2e29f4c39345}, !- Name Medium Office Bldg Occ Rule 1 Day Schedule, !- Sunday Schedule:Day Name Medium Office Bldg Occ Default Schedule, !- Monday Schedule:Day Name Medium Office Bldg Occ Default Schedule, !- Tuesday Schedule:Day Name Medium Office Bldg Occ Default Schedule, !- Wednesday Schedule:Day Name Medium Office Bldg Occ Default Schedule, !- Thursday Schedule:Day Name Medium Office Bldg Occ Default Schedule, !- Friday Schedule:Day Name Medium Office Bldg Occ Rule 2 Day Schedule, !- Saturday Schedule:Day Name Medium Office Bldg Occ Default Schedule, !- Holiday Schedule:Day Name Medium Office Bldg Occ Summer Design Day, !- SummerDesignDay Schedule:Day Name Medium Office Bldg Occ Winter Design Day, !- WinterDesignDay Schedule:Day Name Medium Office Bldg Occ Default Schedule, !- CustomDay1 Schedule:Day Name Medium Office Bldg Occ Default Schedule; !- CustomDay2 Schedule:Day NameSchedule:Year, Medium Office Bldg Occ, !- Name
Fraction,
Schedule:Week:Daily {dafbcefd-3940-41b9-a8ac-2e29f4c39345}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
Schedule:Week:Daily {da10026c-39d8-4c5e-a9c7-9426bbaf6a61}, !- Name Medium Office Infil Quarter On Rule 1 Day Schedule, !- Sunday Schedule:Day Name Medium Office Infil Quarter On Default Schedule, !- Monday Schedule:Day Name Medium Office Infil Quarter On Default Schedule, !- Tuesday Schedule:Day Name Medium Office Infil Quarter On Default Schedule, !- Wednesday Schedule:Day Name Medium Office Infil Quarter On Default Schedule, !- Thursday Schedule:Day Name Medium Office Infil Quarter On Default Schedule, !- Friday Schedule:Day Name Medium Office Infil Quarter On Rule 2 Day Schedule, !- Saturday Schedule:Day Name Medium Office Infil Quarter On Default Schedule, !- Holiday Schedule:Day Name Medium Office Infil Quarter On Summer Design Day, !- SummerDesignDay Schedule:Day Name
Medium Office Infil Quarter On Winter Design Day, !- WinterDesignDay Schedule:Day Name Medium Office Infil Quarter On Default Schedule, !- CustomDay1 Schedule:Day Name Medium Office Infil Quarter On Default Schedule; !- CustomDay2 Schedule:Day NameSchedule:Year, Medium Office Infil Quarter On, !- Name
Fraction,
Schedule:Week:Daily {da10026c-39d8-4c5e-a9c7-9426bbaf6a61}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
Schedule:Week:Daily {d136ff22-4639-4bbb-8eaf-1a235b6f4ee2}, !- Name Office Activity Default Schedule, !- Sunday Schedule:Day Name Office Activity Default Schedule, !- Monday Schedule:Day Name Office Activity Default Schedule, !- Tuesday Schedule:Day Name Office Activity Default Schedule, !- Wednesday Schedule:Day Name Office Activity Default Schedule, !- Thursday Schedule:Day Name Office Activity Default Schedule, !- Friday Schedule:Day Name Office Activity Default Schedule, !- Saturday Schedule:Day Name Office Activity Default Schedule, !- Holiday Schedule:Day Name Office Activity Summer Design Day, !- SummerDesignDay Schedule:Day Name
!- CustomDay2 Schedule:Day NameSchedule:Year, Office Activity,
Schedule:Week:Daily {d136ff22-4639-4bbb-8eaf-1a235b6f4ee2}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
Schedule:Week:Daily {a734cc93-e461-458a-8644-afc4dd19ffa0}, !- Name Office Bldg Equip Rule 1 Day Schedule, !- Sunday Schedule:Day Name Office Bldg Equip Default Schedule,
!- Monday Schedule:Day Name Office Bldg Equip Default Schedule, !- Tuesday Schedule:Day Name Office Bldg Equip Default Schedule, !- Wednesday Schedule:Day Name Office Bldg Equip Default Schedule, !- Thursday Schedule:Day Name Office Bldg Equip Default Schedule, !- Friday Schedule:Day Name Office Bldg Equip Rule 2 Day Schedule, !- Saturday Schedule:Day Name Office Bldg Equip Default Schedule, !- Holiday Schedule:Day Name Office Bldg Equip Summer Design Day, !- SummerDesignDay Schedule:Day Name
!- CustomDay2 Schedule:Day NameSchedule:Year, Office Bldg Equip,
!- Name Fraction,
Schedule:Week:Daily {a734cc93-e461-458a-8644-afc4dd19ffa0}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
Schedule:Week:Daily {431ec6b6-1679-4107-8d51-019088935ac2}, !- Name Office Bldg Light Rule 1 Day Schedule, !- Sunday Schedule:Day Name Office Bldg Light Default Schedule,
!- Monday Schedule:Day Name Office Bldg Light Default Schedule, !- Tuesday Schedule:Day Name Office Bldg Light Default Schedule, !- Wednesday Schedule:Day Name Office Bldg Light Default Schedule, !- Thursday Schedule:Day Name Office Bldg Light Default Schedule, !- Friday Schedule:Day Name Office Bldg Light Rule 2 Day Schedule, !- Saturday Schedule:Day Name Office Bldg Light Default Schedule, !- Holiday Schedule:Day Name Office Bldg Light Summer Design Day, !- SummerDesignDay Schedule:Day Name
Office Bldg Light Default Schedule;
!- CustomDay2 Schedule:Day NameSchedule:Year, Office Bldg Light,
!- Name Fraction,
Schedule:Week:Daily {431ec6b6-1679-4107-8d51-019088935ac2}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
Schedule:Week:Daily {6eb2b308-1351-47ff-87ba-ed5372ba712a}, !- Name Office Infil Quarter On Rule 1 Day Schedule, !- Sunday Schedule:Day Name Office Infil Quarter On Default Schedule, !- Monday Schedule:Day Name Office Infil Quarter On Default Schedule, !- Tuesday Schedule:Day Name Office Infil Quarter On Default Schedule, !- Wednesday Schedule:Day Name Office Infil Quarter On Default Schedule, !- Thursday Schedule:Day Name Office Infil Quarter On Default Schedule, !- Friday Schedule:Day Name Office Infil Quarter On Rule 2 Day Schedule, !- Saturday Schedule:Day Name Office Infil Quarter On Default Schedule, !- Holiday Schedule:Day Name Office Infil Quarter On Summer Design Day, !- SummerDesignDay Schedule:Day Name Office Infil Quarter On Winter Design Day, !- WinterDesignDay Schedule:Day Name Office Infil Quarter On Default Schedule, !- CustomDay1 Schedule:Day Name Office Infil Quarter On Default Schedule; !- CustomDay2 Schedule:Day NameSchedule:Year, Office Infil Quarter On, !- Name Fraction, !- Schedule Type Limits Name
Schedule:Week:Daily {6eb2b308-1351-47ff-87ba-ed5372ba712a}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
Schedule:Week:Daily {77d88b25-5711-40e0-8780-148ac2fd0601}, !- Name Office Bldg Occ Rule 1 Day Schedule 1, !- Sunday Schedule:Day Name Office Bldg Occ Default Schedule 1, !- Monday Schedule:Day Name Office Bldg Occ Default Schedule 1, !- Tuesday Schedule:Day Name Office Bldg Occ Default Schedule 1, !- Wednesday Schedule:Day Name Office Bldg Occ Default Schedule 1, !- Thursday Schedule:Day Name Office Bldg Occ Default Schedule 1, !- Friday Schedule:Day Name Office Bldg Occ Rule 2 Day Schedule 1, !- Saturday Schedule:Day Name Office Bldg Occ Default Schedule 1, !- Holiday Schedule:Day Name Office Bldg Occ Summer Design Day 1, !- SummerDesignDay Schedule:Day Name
Office Bldg Occ Default Schedule 1;
!- CustomDay2 Schedule:Day NameSchedule:Year, Office Misc Occ,
!- Name Fraction,
Schedule:Week:Daily {77d88b25-5711-40e0-8780-148ac2fd0601}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
Schedule:Week:Daily {f62c83df-518a-4c3c-a046-3b26bd8eea33}, !- Name Schedule Day 4,
!- Sunday Schedule:Day Name Schedule Day 4, !- Monday Schedule:Day Name Schedule Day 4, !- Tuesday Schedule:Day Name Schedule Day 4, !- Wednesday Schedule:Day Name Schedule Day 4, !- Thursday Schedule:Day Name Schedule Day 4, !- Friday Schedule:Day Name Schedule Day 4, !- Saturday Schedule:Day Name Schedule Day 4, !- Holiday Schedule:Day Name Schedule Day 4, !- SummerDesignDay Schedule:Day Name
Schedule Day 4,
Schedule Day 4,
Schedule Day 4;
!- CustomDay2 Schedule:Day NameSchedule:Year, People Activity,
Schedule:Week:Daily {f62c83df-518a-4c3c-a046-3b26bd8eea33}, !- Schedule:Week Name 1 1,
!- Start Month 1 1,
!- Start Day 1 12,
!- End Month 1 31;
!- End Day 1Schedule:Constant, Always On Discrete, !- Name ,
!- Hourly ValueSchedule:Constant, Always Off Discrete, !- Name
!- Schedule Type Limits Name 0;
!- Hourly ValueSchedule:Constant, Always On Continuous, !- Name ,
!- Hourly ValueOutputControl:ReportingTolerances, 0.2, !- Tolerance for Time Heating Setpoint Not Met {deltaC} 0.2; !- Tolerance for Time Cooling Setpoint Not Met {deltaC}
Site:Location, BEIJING,
!- Name 39.8, !- Latitude {deg} 116.47, !- Longitude {deg} 8,
!- Time Zone {hr} 32;
!- Elevation {m}SizingPeriod:DesignDay, BEIJING Ann Clg .4% Condns DB=>MWB, !- Name
7,
!- Month 21,
!- Day of Month SummerDesignDay,
!- Day Type 34.9, !- Maximum Dry-Bulb Temperature {C} 8.9, !- Daily Dry-Bulb Temperature Range {deltaC} DefaultMultipliers,
!- Dry-Bulb Temperature Range Modifier Type ,
!- Dry-Bulb Temperature Range Modifier Day Schedule Name Wetbulb,
!- Humidity Condition Type 22.2, !- Wetbulb or DewPoint at Maximum Dry-Bulb {C} ,
!- Humidity Condition Day Schedule Name ,
!- Humidity Ratio at Maximum Dry-Bulb {kgWater/kgDryAir} ,
!- Enthalpy at Maximum Dry-Bulb {J/kg} ,
!- Daily Wet-Bulb Temperature Range {deltaC} 100941,
!- Barometric Pressure {Pa} 3.4, !- Wind Speed {m/s} 180,
!- Wind Direction {deg} No,
!- Rain Indicator No,
!- Snow Indicator No,
!- Daylight Saving Time Indicator
ASHRAETau,
!- Solar Model Indicator ,
!- Beam Solar Day Schedule Name ,
!- Diffuse Solar Day Schedule Name 0.747, !- ASHRAE Clear Sky Optical Depth for Beam Irradiance (taub) {dimensionless} 1.448; !- ASHRAE Clear Sky Optical Depth for Diffuse Irradiance (taud) {dimensionless}SizingPeriod:DesignDay, BEIJING Ann Clg .4% Condns DP=>MDB, !- Name
7,
!- Month 21,
!- Day Type 28.9, !- Maximum Dry-Bulb Temperature {C} 8.9, !- Daily Dry-Bulb Temperature Range {deltaC} DefaultMultipliers,
!- Dry-Bulb Temperature Range Modifier Day Schedule Name Dewpoint,
!- Humidity Condition Type 26.1, !- Wetbulb or DewPoint at Maximum Dry-Bulb {C} ,
ASHRAETau,
!- Diffuse Solar Day Schedule Name 0.747, !- ASHRAE Clear Sky Optical Depth for Beam Irradiance (taub) {dimensionless} 1.448; !- ASHRAE Clear Sky Optical Depth for Diffuse Irradiance (taud) {dimensionless}SizingPeriod:DesignDay, BEIJING Ann Clg .4% Condns Enth=>MDB, !- Name
7,
!- Month 21,
!- Day Type 30.1, !- Maximum Dry-Bulb Temperature {C} 8.9, !- Daily Dry-Bulb Temperature Range {deltaC} DefaultMultipliers,
!- Dry-Bulb Temperature Range Modifier Day Schedule Name Enthalpy,
!- Humidity Condition Type ,
!- Humidity Ratio at Maximum Dry-Bulb {kgWater/kgDryAir} 86200,
ASHRAETau,
!- Diffuse Solar Day Schedule Name 0.747, !- ASHRAE Clear Sky Optical Depth for Beam Irradiance (taub) {dimensionless} 1.448; !- ASHRAE Clear Sky Optical Depth for Diffuse Irradiance (taud) {dimensionless}SizingPeriod:DesignDay, BEIJING Ann Clg .4% Condns WB=>MDB, !- Name
7,
!- Month 21,
!- Day Type 30.5, !- Maximum Dry-Bulb Temperature {C} 8.9, !- Daily Dry-Bulb Temperature Range {deltaC} DefaultMultipliers,
!- Humidity Condition Type 27,
ASHRAETau,
!- Diffuse Solar Day Schedule Name 0.747, !- ASHRAE Clear Sky Optical Depth for Beam Irradiance (taub) {dimensionless} 1.448; !- ASHRAE Clear Sky Optical Depth for Diffuse Irradiance (taud) {dimensionless}SizingPeriod:DesignDay, BEIJING Ann Htg 99.6% Condns DB, !- Name
1,
!- Month 21,
!- Day of Month WinterDesignDay,
!- Day Type -10.8,
0,
!- Humidity Condition Type -10.8,
!- Barometric Pressure {Pa} 2.2, !- Wind Speed {m/s} 340,
ASHRAEClearSky,
!- Diffuse Solar Day Schedule Name , !- ASHRAE Clear Sky Optical Depth for Beam Irradiance (taub) {dimensionless} ,
!- ASHRAE Clear Sky Optical Depth for Diffuse Irradiance (taud) {dimensionless} 0;
!- Sky ClearnessSizingPeriod:DesignDay, BEIJING Ann Htg Wind 99.6% Condns WS=>MCDB, !- Name 1,
!- Month 21,
!- Day Type -1.6,
0,
!- Humidity Condition Type -1.6,
!- Barometric Pressure {Pa} 12,
ASHRAEClearSky,
!- Sky ClearnessSizingPeriod:DesignDay, BEIJING Ann Hum_n 99.6% Condns DP=>MCDB, !- Name
1,
!- Month 21,
!- Day Type -4,
0,
!- Humidity Condition Type -30.1,
ASHRAEClearSky,
!- Sky ClearnessZoneList, Buero,
!- Name B_2OG_4;
!- Zone Name 1People, People 1,
!- Name Buero,
!- Zone or ZoneList Name always on, !- Number of People Schedule Name
People,
!- Number of People Calculation Method 2,
!- Number of People ,
!- People per Zone Floor Area {person/m2} ,
!- Zone Floor Area per Person {m2/person} 0.3, !- Fraction Radiant ,
!- Sensible Heat Fraction People Activity; !- Activity Level Schedule NameZoneInfiltration:DesignFlowRate,
Office Infiltration,
!- Name Buero,
!- Zone or ZoneList Name always on, !- Schedule Name AirChanges/Hour,
!- Flow per Zone Floor Area {m3/s-m2} ,
!- Flow per Exterior Surface Area {m3/s-m2} 0.6, !- Air Changes per Hour {1/hr} ,
!- Velocity Squared Term CoefficientElectricLoadCenter:Inverter:LookUpTable, PV Inverter, !- Name Always_On, !- Availability Schedule Name , !- Zone Name 0.25, !- Radiative Fraction 14000, !- Rated Maximum Continuous Output Power {W} 200.0, !- Night Tare Loss Power {W} 368, !- Nominal Voltage Input {V} 0.839, !- Efficiency at 10% Power and Nominal Voltage 0.897, !- Efficiency at 20% Power and Nominal Voltage 0.916, !- Efficiency at 30% Power and Nominal Voltage 0.931, !- Efficiency at 50% Power and Nominal Voltage 0.934, !- Efficiency at 75% Power and Nominal Voltage 0.930; !- Efficiency at 100% Power and Nominal Voltage
Generator:Photovoltaic, PV:Surface 321, !- Name Surface 321,!- Surface Name PhotovoltaicPerformance:Simple, !- Photovoltaic Performance Object Type 20percentEffPVhalfArea, !- Module Performance Name Decoupled, !- Heat Transfer Integration Mode 1.0, !- Number of Series Strings in Parallel {dimensionless} 1.0; !- Number of Modules in Series {dimensionless}
PhotovoltaicPerformance:Simple, 20percentEffPVhalfArea, !- Name 0.5, !- Fraction of Surface Area with Active Solar Cells {dimensionless} Fixed, !- Conversion Efficiency Input Mode 0.20, !- Value for Cell Efficiency if Fixed ; !- Efficiency Schedule Name
Output:Variable, *,
!- Key Value Zone Air Temperature,
!- Variable Name Hourly;
!- Reporting FrequencyOutput:Variable, *,
!- Key Value Zone Air Relative Humidity, !- Variable Name Hourly;
!- Reporting FrequencyOutput:Variable,,Zone Ideal Loads Supply Air Sensible Heating Energy,hourly; !- HVAC Sum [J] Output:Variable,,Zone Ideal Loads Supply Air Latent Heating Energy,hourly; !- HVAC Sum [J] Output:Variable,,Zone Ideal Loads Supply Air Total Heating Energy,hourly; !- HVAC Sum [J] Output:Variable,,Zone Ideal Loads Supply Air Sensible Cooling Energy,hourly; !- HVAC Sum [J] Output:Variable,,Zone Ideal Loads Supply Air Latent Cooling Energy,hourly; !- HVAC Sum [J] Output:Variable,,Zone Ideal Loads Supply Air Total Cooling Energy,hourly; !- HVAC Sum [J]
Output:Variable,,Generator Produced DC Electric Power,timestep;
Output:Variable,,Generator Produced DC Electric Energy,timestep;
Output:Variable,,Generator PV Array Efficiency,timestep;
Output:Variable,,Generator Requested Electric Power,timestep;OutputControl:Table:Style, HTML;
!- Column SeparatorOutput:Table:SummaryReports,
AllSummary;
!- Report Name 1Output:VariableDictionary, IDF,
!- Key Field Unsorted;
!- Sort OptionOutput:SQLite, SimpleAndTabular;
!- Option TypeLifeCycleCost:NonrecurringCost,
Default Cost,
!- Name Construction,
!- Category 0,
!- Cost ServicePeriod;
!- Start of Costs
