I'm trying to model a residential tower with HRV's in each suite (approximated with one large air loop with air-to-air HX, supply/exhaust fans, and AirTerminal Single Duct Uncontrolled in each zone). Minimum fraction of O/A has been set to 1.0 via a schedule at the air loop Outdoor Air Controller. I have defined People and Design Specification Outdoor Air rates at the Space Type level. I have also tried setting flags in OS:Sizing:System so that "type of load to size on" is set to VentilationRequirement and "System Outdoor Air Method" is set to VentilationRateProcedure. All fans, intakes, terminals etc are autosized.
When I run the model, the resulting airflows are massive (10x what I have defined or more). If I hard-size all the diffusers to the airflow I know I need it works fine. Kind of defeats the purpose of schedules and hierarchies though.
I am at a loss. If anyone is able to assist, would be much appreciated. (tried to upload the OSM file but it wouldn't take)
