I followed the steps in the question "hvac template for standard split ac" to build up a standard split system according to the technical data: http://www.inventorairconditioner.com/air-conditioners/home/wall-mounted/mini-split-apsi-apso-24/
The only changes I made from the default are:
Unitary - Single Speed DX cooling - Cycling - Elec reheat
- OS:AirLoopHVAC:UnitarySystem
Controlling Zone or thermostat location: Τhe relevant zone
- OS:Coil:Cooling:DX:SingleSpeed
Rated Total Cooling Capacity: 6156 W
Rated COP: 3.24
- OS:Coil:Heating:Electric
Nominal Capacity: 6498 W
Diffuser
- OS:AirTerminal:SingleDuct:Uncontrolled
Maximum Air Flow Rate: 0.236 m3/s (Air Circulation 850 CMH Max)
My first question is if my settings are correct according to the technical data?
The second Question is according to openstudio results summary. Using a Unitary - Single Speed DX cooling - Cycling - Elec reheat system the total calculated power consumption for cooling or heating is cooling/heating+fans consumption?
The third question is if I can model an economizer, since the relevant zone is a IT room/Data center space and what are the appropriate settings for an economizer for such a space so as to estimate possible changes in energy consumption
Thanks!
