Hello,
I need to sequence 2 boilers in OpenStudio 1.9.1, i.e. the first boiler will operate all the time and the second boiler will work if the load is greater than the capacity of the first boiler. Based on previous posts, it looks like plant equipment control is currently not possible in OpenStudio GUI. Is that also applicable to OpenStudio 1.10?
Also, is a model done in version 1.9.1 compatible with 1.10?
Regards, Pranav
