I made one simple cube in openstudio and I did intersect surfaces, match surfaces, and visually checked outside boundary condition and also I Created thermal zone for it after that I Moved to OS and ran without HVAC by setting ideal air loads on to test the geometry.But every time simulation run goes until %75 and stops there with showing 5 errors.I do not know what is wrong and at least how can I find these errors to fix them?
