Applied Four Pipe Fan Coil Measure and Pump Usage Seems Low, What may be accounting for this? It should be noted that I modified Four Pipe Fan Coil to have cold/hot water loops instead of cooling tower/boiler/chiller. I also made the pumps continuous. Could it be that they are being counted as interior equipment? Could this also be due to not adding in water fixture units yet? Thanks.
