Hi,
Can anyone here help me with getting started on how to access and get started with energyplus source code.
I want to add two actuators to the object ElectricEquipment:ITE:AirCooled, in order to control the mass flow rate and exit air temperature through the equipment. Currently, there is only one actuator available for controlling the power dissipated within the equipment.
Any help would be much appreciated.
