Hi,
I am trying to model a GSHE with several heat pumps in OpenStudio (V1.10.0). I used the tutorial which is already mentioned in a few other posts (District Cooling and Heating for sizing the GSHE with GSHEPro). The problem is now, that I get very unreasonable cooling / heating loads as well as pump loads. The load distribution before the GSHE was approx. even. I used an autosized variable speed pump. Do you have any suggestions what could be wrong?
Thank you, Phil
C:\fakepath\GSHE Loop.png C:\fakepath\Pie_Loads.png C:\fakepath\Bar_Monthly_Loads.png C:\fakepath\Electricity_Loads.png
