In the GUI, there are some fields that are blue.
It seems that these are fields you can see but cannot modify, is that right?
What's the rationale behind it? Is this something that will be enabled later or something?
For example, the End-Use Category for this ElectricEquipment on the image above: I can see in that there's a setEndUseSubcategory method in the API. Why isn't it enabled in the GUI? Missing the link between the user typing something and behind the scene it modifies the osm?
