I have been working at this for 2 days, although admittedly am a rookie at using this program. I have setup a hot service loop but continue to get this error:
*** 16079 PlantEquipmentOperationSchemes, *** indicated Name=Plant Loop 1 Operation Schemes *** Only last 4 lines before error line shown..... *** 16080 Plant Loop 1 Operation Schemes, !- Name *** 16081 PlantEquipmentOperation:HeatingLoad, !- Control Scheme Object Type 1 *** 16082 Plant Loop 1 Heating Operation Scheme, !- Control Scheme Name 1 *** 16083 , !- Control Scheme Schedule Name 1 * Severe * IP: IDF line~16083 Error detected in Object=PLANTEQUIPMENTOPERATIONSCHEMES, name=PLANT LOOP 1 OPERATION SCHEMES * ~~~ * Field [Control Scheme 1 Schedule Name] is required but was blank * Warning * IP: Note -- Some missing fields have been filled with defaults. See the audit output file for details. * Severe * IP: Blank "required" fields found in input * Severe * IP: Out of "range" values and/or blank required fields found in input * Fatal * IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination.
I have modeled the same loop in a simple single space/zone model and it works no problem.
Any help will be appreciated.
Mark
