I have used a thermostat (Dual Setpoint,18ºC and 25 ºC) for my model considering a HVAC template (Ideal Load Air System). The calculated annual heating and cooling energies is through considering a Variable-air-volume (VAV) terminal unit in Energyplus. I checked the heating and cooling energies through end-uses district cooling and district heating in results, please correct me if I am wrong. Moreover, How can I see (and change) the coefficient of performance (COP) of this VAV?
Thanks a lot in advance!
