asked 9 years ago
ngkhanh's avatar
Measure_test configuration
hi I use notepad++ as text editor for measure writiting. Nornally, i use OS Apply measure or Measure Tab, however, there are some limited with that approach : need refresh to ensure measure data, nay steps to get error codes in stderr file. I got instructions from Measure Writing Guide and link.However, there are still some issues i did not solve, I would like to know about :
  1. Use Notepad++ as Ruby IDE and directly test and trace error like RubyMine in that link - How i use following ruby argument in notepad++ with nppExec like Rubymine ? -e $stdout.sync=true;$stderr.sync=true;load($0=ARGV.shift) -I 'C:\Program Files (x86)\OpenStudio 1.5.0\Ruby'
  2. Measure test file structure : a. seed OSM/Model : i need to apply many measures at same time to get result and trace error for tested measure - i often use OS measure tab to apply mauilple measure - how to do like this with notepad++ or command line ? should i need to apply measure to seed OSM then save it before run measure_test.rb? b. Argument inputs for parallel applying measure: How to assign an hash with argument name and argument value to measure applied in seed OSM like tested measure in measure.rb c. Which syntax should use to get trace on command line screen (notepad++) when running measure. i often use Puts and Runner.RegisterInfo. Which one i need to use or need to use another methods ? d. if i need to include an .epw and other input file csv etc... or idf.file in seed model so which part (def) of measure_test.rb i should input syntax like this ? Where to get OS API about file import/export ?
class NewMeasureTest < MiniTest::Unit::TestCase def setup
add setup for use last run file or rerun again - reporting measure
end def test_agruments # test arguments here (right number, error with bad input, etc...) end def test run measure # get result and assert it end end #class
click to hide/show revision 2
No.2 Revision
a. seed OSM/Model : i need to apply many measures at same time to get result and trace error for tested measure - i often use OS measure tab to apply mauilple measure - how to do like this with notepad++ or command line ? should i need to apply measure to seed OSM then save it before run measure_test.rb? ?
b. Argument inputs for parallel applying measure: How to assign an hash with argument name and argument value to measure applied in seed OSM like tested measure in measure.rb measure.rb
c. Which syntax should use to get trace on command line screen (notepad++) when running measure. i often use Puts and Runner.RegisterInfo. Which one i need to use or need to use another methods ? ?
def setup
add setup #add setup for use last run file or rerun again - reporting measure
measure end def test_agruments # test #test arguments here (right number, error with bad input, etc...) end def test run measure # get result and assert it end end #class
#class
click to hide/show revision 3
No.3 Revision
hi I use notepad++ as text editor for measure writiting. Nornally, i use OS Apply measure or Measure Tab, however, there are some limited with that approach : need refresh to ensure measure data, nay so many steps to get error codes in stderr file. I got instructions from Measure Writing Guide and link.However, there are still some issues i did not solve, I would like to know about :
def setup
end
def test_agruments
  end
  end
end #class
click to hide/show revision 4
No.4 Revision
hi I use notepad++ as text editor for measure writiting. Nornally, i use OS Apply measure or Measure Tab, however, there are some limited with that approach : need refresh to ensure measure data, so many steps to get error codes in stderr file. I got instructions from Measure Writing Guide and link.However, there are still some issues i did not solve, I would like to know about :
d. if i need to include an .epw and other input file csv etc... or idf.file in seed model so which part (def) of measure_test.rb i should input where i need make syntax like this for insert file ? Where to get OS API about file import/export ?
def setup
end
def test_agruments
  end
  end
end #class
