The energy model input table for the LEED submission requires proposed construction assembly U-factor to be calculated in accordance with Appendix A, however spandrel is not mentioned in Appendix A. Do I just submit a U-factor based on the Aggregate R-value of the assembly with glass, air gap, and board insulation?
