Hi, I ran into following warning:
* Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS_ON", Blank Schedule Type Limits Name input -- will not be validated.
As long as I don't use any equipment which needs the Always On Schedule nothing severe happens. But if I for example add a HVAC System were some fans use the constant schedule I get the error message below. I already tried different approaches (tried to change .osm code) but I couldn't find any solution yet. Any idea what could help?
Thank you, Phil
