central heat pump with one chiller heater
I am working on a small project that has a central heat pump with only one module. Is it possible to model a centralheatpumpsystem in E+ with only one chillerheater? The Input Output Reference mentions 1 or more modules but in the Engineering Reference guide it appears that more than one module is required.
click to hide/show revision 3
No.3 Revision
I am working on a small project that has a central heat pump with only one chiller heater module. Is it possible to model a centralheatpumpsystem CentralHeatPumpSystem in E+ with only one chillerheater? ChillerHeaterPerformance:Electric:EIR module? The Input Output Reference mentions 1 or more modules but in the Engineering Reference guide it appears that more than one module is required.required for heat recovery mode or simultaneous heating or cooling modes.
