What is the best way to model a redundant system unit to a chilled water coil to operate during the period in which the plant chilled water is off?
Should I associate a PTAC or PTHP in Thermal Zones tab next to the diffuser?
| 1 | initial version |
| 2 | retagged |
| 3 | No.3 Revision |
What is the best way to model a redundant complementar system unit to a chilled water coil to operate during the period in which the plant chilled water is off?
| 4 | No.4 Revision |
What is the best way to model a complementar complementary system unit to a chilled water coil to operate during the period in which the plant chilled water is off?
