Hello, I got some problems with implement workspace class :
1/ workspace.getObjectsbyType(IddObjectType) - what are available objects ? The IddObjectType links to "empty content" page.
2/ workspace.getObjectbyName(String, ExactMatch = true) - Which name will be checked as follow object?
!- =========== ALL OBJECTS IN CLASS: SETPOINTMANAGER:MULTIZONE:HUMIDITY:MAXIMUM ===========
SetpointManager:MultiZone:Humidity:Maximum,
DOAS humidity max, !- Name
DOAS Ventilation air loop, !- HVAC Air Loop Name
0.008, !- Minimum Setpoint Humidity Ratio {kgWater/kgDryAir}
0.0195, !- Maximum Setpoint Humidity Ratio {kgWater/kgDryAir}
Node 13; !- Setpoint Node or NodeList Name
3/workspace.getObjectbyReference(RefName) - how to create and format reference name ? Have any example for this method ?
Thanks
