Hi I made a few code for measure input :
def arguments(model)
args = OpenStudio::Ruleset::OSArgumentVector.new
d_auto_fan_sch = model.alwaysOffDiscreteSchedule
d_auto_fan_sch.setName("VRF TU auto fan schedule")
always_on = model.alwaysOnDiscreteSchedule
# HVAC schedule choice
chs = OpenStudio::StringVector.new
chs << "Yes"
chs << "No"
sch_chs = OpenStudio::Ruleset::OSArgument::makeChoiceArgument('Optional_sch', chs, true)
sch_chs.setDisplayName("Does HVAC work all day ?")
sch_chs.setDefaultValue("Yes")
args << sch_chs
#pick a schedule
#sched_names = OpenStudio::Ruleset::makeChoiceArgumentOfWorkspaceObjects("HVAC Schedule Name","OS_Schedule_Ruleset".to_IddObjectType,model,true)
all_scheds = model.getSchedules
sched_name_vec = OpenStudio::StringVector.new
all_scheds.each do |sched|
sched_name_vec << sched.name.get
end
sched_names = OpenStudio::Ruleset::OSArgument::makeChoiceArgument('HVAC Schedule name', sched_name_vec, true)
sched_names.setDisplayName("Choose a HVAC schedule")
sched_names.setDefaultValue("#{always_on.name}")
args << sched_names
sched_names1 = OpenStudio::Ruleset::OSArgument::makeChoiceArgument('Supply fan Schedule name', sched_name_vec, true)
sched_names1.setDisplayName("Choose supply fan schedule")
sched_names1.setDefaultValue("#{d_auto_fan_sch.name}")
args << sched_names1
return args
end #end the arguments method
#define what happens when the measure is run
def run(model, runner, user_arguments)
super(model, runner, user_arguments)
#use the built-in error checking
if not runner.validateUserArguments(arguments(model), user_arguments)
return false
end
# setup schedule
s_sup_fan_option = runner.getStringArgumentValue('Supply fan Schedule name',user_arguments)
s_scheds = model.getSchedules
s_scheds.each do |sched|
if sched.name.get == s_sup_fan_option
@@schd1 = sched
end
end
runner.registerInfo(" Set all VRF Terminal unit supply fan schedule as #{@@schd1.name} ")
I created temporary schedule as default schedule for supply fan schedule but they got this warning :
The default value of script argument Supply fan Schedule name (Choose supply fan schedule) Choice, Required Value: (VRF TU auto fan schedule 1) does not match that of the corresponding user argument Supply fan Schedule name (Choose supply fan schedule) Choice, Required Value: VRF TU auto fan schedule (VRF TU auto fan schedule)
each time i try to repeat this measure, they add a new schedule (VRF TU auto fan schedule 1)
How to avoid warning and unnecessary schedule ?
Note : Have any pathway for show the code as cool as in Unmethours in Notepad++ ???
