Is there a way to grab the peak (total or net) monthly electricity demand from the OpenStudio SDK or even EnergyPlus SQL file? I see how to get peak monthly use by fuel type end-use, but summing those together is not only annoying, it also doesn't actually give the monthly peak, because the end-use peaks are not likely to be concurrent.
