Hello, i want to write measure can check and modify objects based on their name content. For examples : if space has "plenum" word in their name so that space's thermalzone would be set as plenum. Have syntax in ruby for observe name string ? Thanks
| 1 | initial version |
| 2 | No.2 Revision |
Hello,
i want to write measure can check and modify objects based on their name content. For examples : if space has "plenum" word in their name so that space's thermalzone would be set as plenum. Have syntax in ruby for observe name string ? Other case, action base on external sources like .csv, .doc, etc
Thanks
| 3 | retagged |
Hello, i want to write measure can check and modify objects based on their name content. For examples : if space has "plenum" word in their name so that space's thermalzone would be set as plenum. Have syntax in ruby for observe name string ? Other case, action base on external sources like .csv, .doc, etc Thanks
