Referenced question: Plant Loop Operation Scheme in Open Studio
OpenStudio currently generates the Plant loop operation scheme on forward translation. In my case it's definitely not doing what I want and my waterside fluid to fluid heat exchanger is not turning on as a result.
I see that in 1.10.1 (but it's been like this for a while) in the GUI if you look at the Plant Loop objects there are dropdowns to specify the operation schemes.
Can I create my operation schemes using the SDK, assign them to my plant loop are NOT have OpenStudio trying to remove them or add any other schemes?
