Hi everybody,
I want to use OpenStudio for a single house. I had create a model with different spaces and thermalzones. Now I want to create the Heating in this house. It should be an european heating system. This means without airflow, cooling and with a convective system. Normally there is a boiler, which heats the water, which flows to the different rooms and heat the room air by a convective body. It is possible to create this system in OpenStudio? Yes, how can I create this?
Thanks a lot!
