When I create an easy model of a thermal zone in which there is an illuminance map, a daylight sensor, and then I suceed to finish calculation using radiacne measure, there are no results of illuminace map, nor daylight sensor illuminance.
Although the calculation is finished, there are many error messages; WARN: an error has occurred; no results for space 'Space_101'.
How is this solved? (I am using OS 1.8.5)
