Hello, I was doing the HVAC system and I am a bit stuck. The model I'm doing has a gas based radiant heating system where there are pipes under the floors which has heated water running through them. The water is heated by a gas boiler probably (we're not sure if we want to use gas or electricity). Is there any way I can model this in Open studios ? I tried to do it but I got totally confused.
Kind Regards, Rafid Khan
