Hi all, While the legacy plug-in are continuously updated to work with latest energyplus, The OS Apps is much better in creating geometry object and setup initial configuration with many template and user script measure. However, the OS Apps still lacks a lot HVAC objectives/fields and significant slower than E+ running time. I would like to ask about the good practice for from/to idf and osm especially after adding OS non-imported object to pdf file. Curretly OS cant not import anythings other than geometry, load and schedule. Thanks
