Hi All,
My model has 286 thermal zones. The zones are conditioned by DOAS, radiant slabs, radiators and fan coil units. The chilled and hot water for the systems is provided by a ChillerHeater:Absorption:DirectFired component on the plant side in the energy model. My simulation runs successfully but there seems to be some issue with results in the HTML file. Various cells in the HTML tables only have the value -1.#J.
I am trying to figure out if there is some issue with my model or if it has to do with just the results reporting. Has anyone else had similar issues with the results table in the HTML file? Any help is appreciated.
Thank you, Raghu
