Hi there, when assigning different constructions sets to two adjacent spaces (using the plugin 'set attributes for selected spaces'), the interzone surface inherits two different constructions which results in the following severe e+ error:
* Severe * GetSurfaceData: Construction EA INTERIOR PARTITION WALL REFRIGERAION 1 of interzone surface 00REF-01 - WALL 090:A does not have the same number of layers as the construction EA INTERIOR PARTITION WALL of adjacent surface 00MEC-02 - WALL 270:A * ~~~ * ...this problem for this pair will not be reported again. The simulation fails. This problem is resolved by manually assigning construction to one of the referenced surfaces. e.g. set, A INTERIOR PARTITION WALL REFRIGERAION construction for 00MEC-02 - WALL 270:A.
I was expecting that when you a assign a construction set to a space all the constructions of adjacents surfaces would be updated to match the new construction set. How should the workflow be in order to no have assign constructions manually?
Thanks.
