Good evening,
I have the follow error message:
Program Version,EnergyPlus, Version 8.2.0-8397c2e30b, YMD=2015.12.18 15:42,IDD_Version 8.2.0 * Severe * IP: IDF line~8761 Object=WATERUSE:CONNECTIONS, name=WATER USE CONNECTION, Required Field=[Water Use Equipment 1 Name] was blank. * Warning * IP: Note -- Some missing fields have been filled with defaults. See the audit output file for details. * Severe * IP: Possible incorrect IDD File * ~~~ * IDD Version:"IDD_Version 8.2.0" * ~~~ * Version in IDF="8.2" not the same as expected="8.2" * ~~~ * Possible Invalid Numerics or other problems * Fatal * IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=2 ..... Last severe error=IP: Possible incorrect IDD File *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 1 Warning; 2 Severe Errors; Elapsed Time=00hr 00min 4.00sec __________________________
I already do everything I can to correct this problem... could you please help me?
Sincerely yours, Sandra Matos
