I am setting up a heat recovery chiller and want to connect the recovered heat to a campus hot water loop. Is this arrangement possible. Or is there a work around that I could use to determine the total heat rejected by the heat recovery chiller.
| 1 | initial version |
| 2 | No.2 Revision |
| 3 | No.3 Revision |
