What object should I use to model radiators in a room? ZoneHVAC:Baseboard:RadiantConvective:Water or ZoneHVAC:HighTemperatureRadiant. In my case I have system with a boiler with a water loop to supply hot water to several radiators in several room.
| 1 | initial version |
| 2 | retagged |
| 3 | No.3 Revision |
| 4 | No.4 Revision |
What object should I use to model radiators in a room? ZoneHVAC:Baseboard:RadiantConvective:Water ZoneHVAC:Baseboard:RadiantConvective:Water or ZoneHVAC:HighTemperatureRadiant. ZoneHVAC:HighTemperatureRadiant. In my case I have system with a boiler with a water loop to supply hot water to several radiators in several room.
| 5 | retagged |
| 6 | retagged |
