Hi,
I want to know what´s the object that I've to use to model a only sensible heat recovery?
| 1 | initial version |
Hi,
| 2 | No.2 Revision |
Hi,
I want to know what´s the object that I've to use to model a only sensible heat recovery?recovery? I found in openstudio a sensible and latent heat recovery, but in my case I don't have latent heat recovery. Should I put the values of latent effectiveness to 0?
| 3 | No.3 Revision |
Hi,
I want to know what´s the object that I've to use to model a only sensible heat recovery? I found in openstudio a sensible and latent heat recovery, but in my case I don't have latent heat recovery. Should I put the values of latent effectiveness to 0? 0%?
