Natural ventilation to reduce cooling loads
I'm modeling a very simple house with a single thermal zone with CAV DX coil cooling with a single air duct. In order to test cooling loads reduction with window opening, I constructed a simple AFN for natural ventilation, using NoMultizoneOr Distribution and Surface Average Calculation method (I am a novice to Airflownetwork (AFN) though).
However, even though the AFN is set, I find no change in cooling loads. Can anyone explain why? and how to fix this problem? Thanks in advance. My inputs are as follows:
!- =========== ALL OBJECTS IN CLASS: AIRFLOWNETWORK:SIMULATIONCONTROL ===========
AirflowNetwork:SimulationControl,
EllisAirNetwork,         !- Name
NoMultizoneOrDistribution,  !- AirflowNetwork Control
SurfaceAverageCalculation,  !- Wind Pressure Coefficient Type
,                        !- AirflowNetwork Wind Pressure Coefficient Array Name
,                        !- Height Selection for Local Wind Speed Calculation
LowRise,                 !- Building Type
500,                     !- Maximum Number of Iterations {dimensionless}
LinearInitializationMethod,  !- Initialization Type
0.0001,                  !- Relative Airflow Convergence Tolerance {dimensionless}
0.000001,                !- Absolute Airflow Convergence Tolerance {kg/s}
-.5,                     !- Convergence Acceleration Limit {dimensionless}
90,                      !- Azimuth Angle of Long Axis of Building {deg}
0.95;                    !- Ratio of Building Width Along Short Axis to Width Along Long Axis
!- =========== ALL OBJECTS IN CLASS: AIRFLOWNETWORK:MULTIZONE:ZONE ===========
AirflowNetwork:MultiZone:Zone,
Thermal Zone 1,          !- Zone Name
Constant,                !- Ventilation Control Mode
Ellis House ClgSetp 1,   !- Ventilation Control Zone Temperature Setpoint Schedule Name
0.5,                     !- Minimum Venting Open Factor {dimensionless}
3,                       !- Indoor and Outdoor Temperature Difference Lower Limit For Maximum Venting Open Factor {deltaC}
10,                      !- Indoor and Outdoor Temperature Difference Upper Limit for Minimun Venting Open Factor {deltaC}
0.0,                     !- Indoor and Outdoor Enthalpy Difference Lower Limit For Maximum Venting Open Factor {deltaJ/kg}
300000.0;                !- Indoor and Outdoor Enthalpy Difference Upper Limit for Minimun Venting Open Factor {deltaJ/kg}
!- =========== ALL OBJECTS IN CLASS: AIRFLOWNETWORK:MULTIZONE:SURFACE ===========
AirflowNetwork:MultiZone:Surface,
Sub Surface 1,           !- Surface Name
VentOpening,             !- Leakage Component Name
Sfacade,                 !- External Node Name
0.6,                     !- Window/Door Opening Factor, or Crack Factor {dimensionless}
0.1,                     !- Minimum Venting Open Factor {dimensionless}
2,                       !- Indoor and Outdoor Temperature Difference Lower Limit For Maximum Venting Open Factor {deltaC}
3,                       !- Indoor and Outdoor Temperature Difference Upper Limit for Minimun Venting Open Factor {deltaC}
300000,                  !- Indoor and Outdoor Enthalpy Difference Upper Limit for Minimun Venting Open Factor {deltaJ/kg}
Always On;               !- Venting Availability Schedule Name
Sub Surface 4,           !- Surface Name
Nfacade,                 !- External Node Name
0.4,                     !- Window/Door Opening Factor, or Crack Factor {dimensionless}
1,                       !- Indoor and Outdoor Temperature Difference Lower Limit For Maximum Venting Open Factor {deltaC}
!- =========== ALL OBJECTS IN CLASS: AIRFLOWNETWORK:MULTIZONE:COMPONENT:SIMPLEOPENING ===========
AirflowNetwork:MultiZone:Component:SimpleOpening,
VentOpening,             !- Name
0.001,                   !- Air Mass Flow Coefficient When Opening is Closed {kg/s-m}
0.65,                    !- Air Mass Flow Exponent When Opening is Closed {dimensionless}
0.0001,                  !- Minimum Density Difference for Two-Way Flow {kg/m3}
1;                       !- Discharge Coefficient {dimensionless}
!- =========== ALL OBJECTS IN CLASS: AIRFLOWNETWORK:MULTIZONE:EXTERNALNODE ===========
AirflowNetwork:MultiZone:ExternalNode,
Sfacade,                 !- Name
6,                       !- External Node Height {m}
W;                       !- Wind Pressure Coefficient Values Object Name
Nfacade,                 !- Name
!- =========== ALL OBJECTS IN CLASS: DESIGNSPECIFICATION:OUTDOORAIR ===========
DesignSpecification:OutdoorAir,
Outdoor Air,             !- Name
Sum,                     !- Outdoor Air Method
0,                       !- Outdoor Air Flow per Person {m3/s-person}
0,                       !- Outdoor Air Flow per Zone Floor Area {m3/s-m2}
0,                       !- Outdoor Air Flow per Zone {m3/s}
0;                       !- Outdoor Air Flow Air Changes per Hour {1/hr}
Sfacade,                 !- Name
Nfacade,                 !- Name
    Sfacade,                 !- Name
    Nfacade,                 !- Name
