Is there a way to model hot gas reheat in OpenStudio? Currently the only way I have been able to model it is to export an idf from OpenStudio and add the Coil:Heat:Desuperheater in the idf Editor then run the simulation with EP-Launch.
![]() | 1 | initial version |
![]() | 2 | retagged |
