So when I run my model, I get some errors with my idf file. When I search the errors in my model I get the following, when I try to find this problem subsurface, I cannot find it anywhere! I said to search the whole model, and nothing comes up, is there a way to fix this by applying some sort of measure, I already tried running diagnostics and removing orphan subsurfaces:
Error: Currently unable to translate Object of type 'OS:SubSurface' and named 'Sub Surface 200', because it has more vertices than allowed by EnergyPlus. Error: Currently unable to translate Object of type 'OS:SubSurface' and named 'Sub Surface 200', because it has more vertices than allowed by EnergyPlus. Error: Currently unable to translate Object of type 'OS:SubSurface' and named 'Sub Surface 200', because it has more vertices than allowed by EnergyPlus.
