OpenStudio Run Errors
Hi all,
I am having trouble trying to get my OpenStudio model to run. Normally I would start trying to run it and work through the errors with the error text file. However when I first tried to do this, everything below the ModelToIdf was "Out Of Date". Any solution to this. I think it might be that my E+ isn't the correct version or something along those lines. My OpenStudio version is 1.9.5.
Below is the image of what I am talking about.image description
Hi all,
Below is the image of what I am talking about.about. image description
This is also one of the errors that come up when I open errors and warnings in the ModelToIdf file.
Error with conversion: C:\Git\OpenStudio_2\openstudiocore\src\model\ModelObject.cpp@913 : Unable to deduce a value for boolean field 10 in Object of type 'OS:AirTerminal:SingleDuct:VAV:NoReheat' and named 'VAV1SE'.
Hi all,
Below is the image of what I am talking about. image description
Hi all,
This is also the one of the errors error that come comes up when I open errors and warnings in the ModelToIdf file. This is what is causing the simulation to not run. The others errors were simple things such as constructions.
