Hi! I have to model a chilled ceiling, with water.
The manufacturer gave me some standard data as Inlet and Outlet water temperatures and thermal power referred to an internal ambient temperature (air temperature).
- Once I set all the inputs and obtain the results, is there a way to check the design power of the surface? I just want to compare it with the one given me from the manufacturer.
- Is there a way to model a heated ceiling? I think I can't use a heated floor because the heat transfer coefficients are different.
Thanks!
