Hi, I would like to ask is Open Studio is compatible with other softwares except Sketch Up. Does it work wit files exported from Rhino5? and does it work with meshes, NURBS etc.? Thank you!
| 1 | initial version |
| 2 | No.2 Revision |
Hi, I would like to ask is if Open Studio is compatible with other softwares except Sketch Up. Does it work wit files exported from Rhino5? and does it work with meshes, NURBS etc.? Thank you!
| 3 | retagged |
Hi, I would like to ask if Open Studio is compatible with other softwares except Sketch Up. Does it work wit files exported from Rhino5? and does it work with meshes, NURBS etc.? Thank you!
