This bug report applies to the EnergyPlus package bundled with OpenStudio 1.9.0, version for Linux.
When trying to run EnergyPlus separate from OpenStudio, I first entered in command terminal:
export ENERGYPLUS_DIR=/usr/local/share/openstudio-1.9.0/EnergyPlus-8-3-0
export PATH=$PATH:$ENERGYPLUS_DIR
export ENERGYPLUSWEATHER=$ENERGYPLUSDIR/WeatherData
After this, the following command should start a simulation:
runenergyplus EPinputfile.idf weatherfile.epw
However, this fails with the following error message:
..did not find 'EnergyPlus'
