Hi guys,
I’m facing a few troubles with OS 1.9.4 (win 7 64 bits machine, have the right tools installed and indicated in OSapp), above all with the measures tab.
I’ve just uninstalled and reinstalled OS 1.9.4. All the applications are in default directories. The general problem is that the OSapp often shuts down when adding o removing a measure.
I’m trying to use 2 important measures: Radiance daylighting measure and Night Ventilation (but I think it’s a general problem with Ruby o something like this).
Radiance Daylighting Measure
I sent a message in this post last week, and they told me (sending the file) that it ran well on other machine, so I guess it comes from something in mine…? Changing a few things today (uninstalling Ruby and other Radiance versions from C: hard desk) I have a “new” sterr file:
DL is deprecated, please use Fiddle skies\render_sky_input skies\render_sky_skyfuncs
So it runs the simulation but none of the Radiance results expected met… All values are 0.
fan_assist_night_ventilation
Should be important to mention that 2 days ago, it didn’t show this message… Now I can’t load the measure. I have this message:
Process exited with a non-zero exit code of: 1
C:/Users/mathieu/AppData/Local/Temp/OpenStudio.gP6008/ApplyMeasureNow/UserScript/user_script.rb:293:in block in run': undefined methodname' for nil:NilClass (NoMethodError)
from C:/Users/mathieu/AppData/Local/Temp/OpenStudio.gP6008/ApplyMeasureNow/UserScript/user_script.rb:291:in each'
from C:/Users/mathieu/AppData/Local/Temp/OpenStudio.gP6008/ApplyMeasureNow/UserScript/user_script.rb:291:inrun'
from in.rb:355:in `<main>'
Script executing from: C:/Users/mathieu/AppData/Local/Temp/OpenStudio.gP6008/ApplyMeasureNow/UserScript Found argument 'design_flow_rate' with value '1000'. Found argument 'fan_pressure_rise' with value '500'. Found argument 'efficiency' with value '0.65'. Found argument 'ventilation_schedule' with value '{82b272f4-b56c-438b-a92a-24e2316ad393}'. Found argument 'min_outdoor_temp' with value '55'. Found UserScript 'Fan Assist Night Ventilation'. No zone equipment found, adding exhaust fan to avoid OpenStudio issue. No zone equipment found, adding exhaust fan to avoid OpenStudio issue.
Do you have any idea, suggestion, please…?
Please tell me if you want me to write to different messages.
Thanks!
Regards,
Mathieu
