Hi all,
I am trying to model some infloor radiant heating and have a questions regarding the links. When I drag the equipment onto the zone and look at its properties, there is 2 links. One for cooling and heating. The infloor heat I am trying to model is only used for heating, so I link that to my hot water loop. For the cooling section of the device what should I be setting all the values too? I assume the maximum cold water flow should be 0, and then can I just not apply a link to the "cooling coil"? Or would it be better to implement a different type of equipment to simulate the infloor radiant heating.
It should be mentioned I am working in OpenStudio
Thanks
