Hey all,
How can you set the "UserDefinedFluidType" in a plant loop? I change the Fluid Type to "UserDefinedFluidType" but then under the User Defined Fluid Type tab it is blank. I just need a way to define the properties of the fluid I would assume. The fluid will be a 40%Glycol fluid.
