I have a idf file created with designbuilder and want to implement a four pipe beam which was newly incorporated in energyplus version 8.4. No graphical user interface appears to have adopted version 8.4 yet.
I created a Induction unit in design builder and exported the idf file hoping to change the system to a FourPipeBeam based on the example file. I chose a induction unit model as it seemed closest to the FourPipeBeam and gives me all the nodes and connections.
But the process seems too tedious and there are a lot of errors.
Just wondering how do you usually use a energy plus example idf file of a system and incorporate it into your model of the building.
