It seems that my surface matching algorithm is broken, is there a way to get it to work in the whole model? It only does random spots?
| 1 | initial version |
| 2 | No.2 Revision |
It seems that my surface matching algorithm is broken, is there a way to get it to work in the whole model? It only does random spots?spots? I used the OpenStudio surface matching measure, and said to do the whole model, but it does not do the whole model properly.
| 3 | retagged |
It seems that my surface matching algorithm is broken, is there a way to get it to work in the whole model? It only does random spots? I used the OpenStudio surface matching measure, and said to do the whole model, but it does not do the whole model properly.
