HI! I hope you're all doing well.
In the past few weeks we've been creating our country's standard file (openstudio-standards) based on the NREL's OpenStudio Standards (the fork now is: BHRC standards.)
The generator builds the file successfully and then tests goes without error but when I replace the JSON files of OpenStudio with the one I have generated OpenStudio loads non of them and the Inspector loads empty.
What should I do?
Thanks a lot as always for your kind kind helps Pouya
